Question about Belling Kitchen Ranges
Belling Countrychef, main oven will light but wont stay on. Gas oven!
  • cpparker33 Jul 05, 2008
    Read the problem the oven lights therefore its not the ignitor, the oven wont stay on, when you take your hand of the oven button?
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
On my countrychef 100g gas range oven lights but when control knob is released it goes out
The heat sensor that detects the flame is not working properly. Consult a qualified Gas Engineer as this is a safety critical item.
Dec 26, 2010 | Belling Microwave Ovens
There is no heat coming out of my fan oven, a Belling Countrychef 100df Range Cooker. The fan comes on and the light goes on to show it is on but there is just no heat ! It is about 7 years old. What is...
If the fan is working o/k, then it is sure to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 17, 2010 | Ovens
The main oven flame wont stay on when lighting
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 06, 2010 | Belling FarmHouse 931 Gas Kitchen Range
Belling Farmhouse Cookcenter Model 111 main oven wont reach temp
Same problem here too. Plus the in-game assisted oven has a similar problem inasmuch as the flame goes straight to max and won't reduce. Please help
Apr 05, 2010 | Belling FarmHouse 931 Gas Kitchen Range
My belling countrychef 100 G oven won't stay lit
There is a good possibility you have a faulty component called a thermocouple, this is heated by the pilot light of your oven and is the most common cause of flame outage.
I would recommend you get a 'Gas Safe' qualified engineer to check it. The thermocouple should be no more than £30.
I hope this helps.
Jul 08, 2009 | Kitchen Ranges
Flame will not stay lit in oven of countrychef 100g
Yes very simple. There is a bulb the flame is heating with a small tube that runs to the gas valve this is the saftey sensor that is bad called a thermo-couple , they are common to go out and should be easy to find online. Let me know if you have any other questions.
Phil
Apr 10, 2009 | Ovens
Gas oven wont stay on
If this is electronic ignition, then chances are the burner or ignitor nub has residue on them, preventing the flame detection system from keeping the gas on.
Use warm soapy water and a plastic scrub brush to thoroughly clean the burner cap, burner base, and ignitor nub.
Jan 25, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Kitchen Ranges Logo
463 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
