Question about HP Photosmart C6280 Printer
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Hello, I have a new HP Photosmart C6280 All-in-One running on Vista. Today it decided to simply stop printing it is in a non usb 2, 4 port hub with other devices plugged in via a usb extensino cord to a usb 2 port in my computer.
Any ideas? it gives a Error - Printing message in the computers print properties.
Jay
  • 1 more comment
  • Jaymie Knight Jul 10, 2008
    Hello I have tried deleting the USB Support in Device Manager, it has copied the printer i.e Copy 3 in printers folder and still is unable to print.
  • Jaymie Knight Jul 14, 2008
    I have deleted unprinted docs and deleted the printer and 2 copies from printers folder. I Haev used the wizard to install the printer again and now when I hit print it does not show any jobs in teh print properies box. zero jobs pending
    It has duplicated a few more usb ports that I think i need. Can I send a doc with screen dump?
    Hmm..? it is connected directly to the computer
    Master:
  • 497 Answers
Have u tried reinstalling the drivers..use the one given aong with the Vista cd...and for help use this link
http://h10025.www1.hp.com/ewfrf/wc/d...402150&lang=en
and please do keep us updated...and by the way what is error message?
hope this works for u..All the best
Thank you for using Fixya
Posted on Jul 14, 2008
    Genius:
  • 1,226 Answers
Please unistall the old drivers and then download update drivers from the manufacturers website and install. or REstore your system backward from the dates where the printer working properly.
melnavz
Posted on Jul 10, 2008
  • Emelio Navaja
    Emelio Navaja Jul 10, 2008
    besure that toner or ink cartridges are new.
    President:
  • 2,712 Answers
Plug the printer directly to the PC..dont use the hub, especially if you are sharing it with devices you are using..
  • 2,071 Answers
The error message “ Printer not activated – Error Code 20 ” is displayed on the computer when printing. Before proceeding to the solution, please verify that the printer or all-in-one is working by printing a self-test page and also verify USB connectivity from the printer to the computer. Solution Step one: Make sure the desired printer is set as the default printer
  1. Click Start and then click Printers and Faxes to open the Printers folder.
  2. If the desired printer icon is missing, please go to Step two.
  3. Make sure the desired printer has a check mark next to it which indicates it is set as the default printer.
  4. If the desired printer does not have a check mark next to it, right-click the printer icon and then click “ Set as Default Printer ”.
  5. Right-click the printer icon, and then click Print Test Page to print a Windows self-test page.
  6. If the Windows test page prints successfully, close all windows and try printing from the application you were using before.
  7. If the Windows test-page does not print, go to Step two.
Step two: Re-install the USB Composite Device from Device Manager
  1. Click Start and then Run .
  2. Type devmgmt.msc in the Run window and then press Enter to open the Device Manager Window.
  3. Click the plus sign (+) next to Universal Serial Bus Controllers.
  4. Right click USB Composite Device , click Uninstall , and then click OK .
  5. Disconnect the USB cable from the computer and then reconnect it.
  6. Follow the instructions in the Found New Hardware wizard to install the drivers.
  7. Right-click the printer icon, and then click Print Test Page to print a Windows self-test page.
  8. Close all windows and try printing from the application you were using before.
Step three: Reinstall the HP Software If the above steps do not resolve the issue, please uninstall and reinstall the HP software. Cause The error may be caused if the wrong printer is set as the default printer, the printer driver is missing, or if there are conflicts in the device manager.
  • HP Master
  • 19,396 Answers
1 Check cartridges, eventually remove and plug back in cartridges.
2 Inspect pinter for small pieces of paper or foreign objects.
3 disconnect usb from hub and plug it directly to the PC on a different usb port.
If the above does not fix it do the following procedure:
Unplug printer from usb
Go to printers under control panel and remove printer, chose remove all driver files if asked.
Reinstall drivers from disk or let Vista reinstall drivers automatically. If you reinstall from disk you must chose 'run the program as administrator' under vista, or it won't work.
Connect printer only when required by program if installing from disk.
  • Ginko
    Ginko Jul 11, 2008
    Well, do not play with your system properties and device manager if you are not sure about what you where doing.
    You have three installed printer, and probably some non working usb driver, because you removed the usb root hub from installed devices, and you reinstall it with usb plugged in.
    Now remove the three printer copies that had been installed, and check on installed device that you do not have any yellow mark on USB drivers, if you have some remove correspondent device and start computer with no additional usb devices installed, then let windows install drivers by itself.
    Once you fix eventual usb problems, just follow the standard reinstall drivers procedure in my previous post.
    If reinstalling drivers does not fix it, it is probably a fault with the printer, in this case possibly test the printer on a different computer, if it still does not work it is faulty.
    Genius:
  • 2,785 Answers
Plz try by directly connecting the printer to usb port, if the problem is not solved, plz go to device manager and uninstall the usb printing support from the usb list then click on the new hardware found in the menu bar.If still the problem is not solved then try by reinstalling the drivers and try with new usb cable
  • HP Master
  • 13,433 Answers
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Posted on Jul 05, 2008
  • Ekse Jul 10, 2008
    well thanks for the rejection but atleast comment back on whats up..
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
2 colors not working but have new cartrages.
Please check if u have print heads . If not run a nozzle clean & re- alignment , either on the printer menu or on maintenance through ur printing software
May 15, 2012 | HP PRT HP|OFFICEJETPRO K5400DTN INKJET...
Just got a new laptop. Tried to install HP Photosmart C 6280. Installation failed because new laptop has Windows7 and v.9.0.2 uses 2000, xp or Vista. Is there a fix?
Try using the compatability tool that is integrated with Windows 7. Do a right click on the Setup.exe file of Photosmart and select Troubleshoot Compatability. Then select, This program worked with an earlier version of Windows, and then select Windows XP SP2. Run the program and if it works choose the option that tells the system the program installed properly. Hope this helps
Aug 18, 2011 | HP Photosmart C6280 Printer
Users manual for hp photosmart C6280
The user manual (and other guides) for the HP Photosmart C6280 are available from HP at: http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
The tray selection is not listed well in the index, but the informaton you are looking for is probably found in pages 38-40 which deal with using the photo tray.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 02, 2008 | HP Photosmart C6280 Printer
HP Photosmart C6280 Printer Logo
214 people viewed this question
Seeker5211
Seeker5211
