Question about Lexmark Office Equipment & Supplies
I turn my printer on and the carriage slam to the side with a slamming sound and it says there's a jam in the printer, and it will not print
  • Anonymous Nov 26, 2008
    Ink Cartrage Holder is slaming to the left and right then i get continuous blinking on the power button.
    Genius:
  • 2,785 Answers
Your printer needs servicing
Posted on Jul 05, 2008
Hp 7520 carriage slams back & forth
Sounds like a defective printer that you may need to replace. If you ever need the ink for it, please let me know. Damien @ iPrint Technologies - 818.700.7419
Aug 28, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
Why is printhead suddenly slamming to the left?
Just drip a few drop of oil on the carriage rod. This might solve the problem.
May 03, 2014 | Kodak ESP Office 2150 All-in-one Printer
Optical strip seems to shake and sometimes printer carriage slams to a halt in the middle of a print. Local technician says that optical strip is at proper tension. Printer thinks that it is a paper jam,...
I guess that your printer is shaking too much. I had same problem before. Tighten all bolts in the stand. Leaning one side (preferable cartridge slot side) against the wall or heavy furniture firmly. Avoid printing fast mode. It might help, my printer's odometer now reached over 200000 sq feet
Jan 13, 2011 | HP Designjet Z6100 InkJet Printer
The cartridge bay goes crazy and slams both sides of the printer. Thus, this will not let me print. I was printing fine, and then I heard a slam, and a notification popped up sayin there was a problem with...
Clean encoder strip, thin plastic strip runs width of machine pararell to silver scan rail. Ensure it is running threw carriage smoothly otherwise the light that read it is dodgy, this will be unecomical to fix unless dirty strip
Nov 07, 2009 | Lexmark Z715 InkJet Printer
Part FELL off!
It sounds like this is the is the position indicator tape. There should be a small hole on both ends of it that fits over a small plastic tab on eich side of the printer. It normally needs to fit in a small **** on the back side of the print carriage.
With the printer turned off & preferably unplugged, gently slide the print carriage to the center of its range of motion. Ensure that this plastic strip is still attached on the opposite end and it feeds through the back of the print carriage. There should be a small tab to attach the free end to similar to what you see on the other end. The strip should be taut but not tight enough to stretch and it should not sag. Exactly where the attach vary somewhat depending on make and model, but they are all similar.
Mar 22, 2009 | Lexmark JetPrinter Z515 InkJet Printer
Ink carriage moves quickly side to side
The is because the sensor bar is dirty or has finger prints on it, (It's like a thin flim strip that runs along side the printer head - the full length of the printer)
Clean it and remove the dirt and it should print ok. (You proberly put finger prints on it when you checked for the jam!)
DO NOT USE CHEMICALS TO CLEAN IT
Mar 21, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
Carttridge is slamming against side of printer, light is flashing, no printing, no paper jam
I suspect the problem for both of you is either the blockage of the position sensing path (a slot in the carriage) or the plastic band that is imprinted with many vertical stripes and lets the printer know where it is and needs to go is not where it belongs.
Open the printer as you would to change cartridges and look carefully with a flashlight inside for a thin ~ 6mm (~1/4") plastic strip and insure that it is clean and stretched between both ends. One end is normally anchored to the chassis, the other attached to a spring suspension.
Nov 05, 2008 | HP D1560 Deskjet Printer InkJet
Okidata 320 Turbo print head carriage slamming
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
Feb 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Lexmark x1270
It's losing knowledge of where the carriage is on the rail, hence the carriage tring to escape threw the side
and I'm concerned with your L-01 piece is one of these?
If so thats the cover switch but to my knowledge doesn't create the slam, that usally known to be a plasic strip that runs the width of printer, not intact, Dirty or not running threw the carriage sensor
Tell me more and I'll continue.
Jan 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
Print cradel CRASHES!! into the right side of my printer
There is a thin, clear plastic strip that guides the carriage & stops it from slamming like that. it is broken sadly. try getting one from ebay and switching it out. We got ours for like $13 shipped
Sep 03, 2007 | HP PhotoSmart 7760 InkJet Printer
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
