Question about Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius wma56
The wash is on for far to long! the water will not go out of the drum just keeps washing around 5 hours. tried restarting a few times. please help. mike
  • coralpoppy Aug 25, 2008
    I think that there is a blockage somewhere, but I don't know where to unblock it ?
Hiya my name is Robin i have a probelm with my washing machine i wonder where can find the tap on the main motor as well as the belt which goes around the motor.
thank u very much
Posted on Oct 29, 2008
Hi tryed that but dident work .then tested the pipe from the filter to the tap .yes it was blocked, yuk so much mess.after i cleaned the pipe it worked fine. to see if the pipe was clear i put my mouth to the pump end and blew.no air went through so i knew it was the pipe from the pump to the waste system.
happy days.
Posted on Aug 22, 2008
    President:
  • 1,462 Answers
Probably due to not draining.
there is a filter in the system which you need to remove and clean. possible also that you have a foreign object jamming the pump.
take the back panel at the bottom of the machine off.
you will see a large diameter hose going from the bottom of the tub to the pump.remove this hose at the tub end. lots of water will come out so make sure none goes on the motor. the filter is inside this hose. take out and clean
let me know if this doesn't work
Posted on Jul 05, 2008
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Jan 23, 2013 | Hotpoint Aquarius WMA56 Front Load Washer
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine keeps filling with water
I would say your water level sensor is broke. It reads the water level and cuts it off when it is appropriate.
Feb 27, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Can you help? we have a hotpoint aquirius 1100 waher, the drum seal seems to keep getting dirty, wife keeps machine spotless and allways cleans seal, but constantly gets brown scum going onto washing and...
hi my trick is .................... WHITE VINAGER ...YES VINAGER ... right get 5 ltrs of white not brown or your cloths will STINK :))) now wip some around seal .... tip 2 ltrs into drum ...and rest into powder capartment .... leave for 5 min ...then put on boil wash ...DONT PUT ANY THING ELS IN ..IE CLOTHS OR POWDER.. it normally gose .. wash through x2 times with powder ect b4 any cloths go in . bsc appliances bristol 07779933829 postal service too.
Feb 26, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Drum will not empty water
sounds like its not going thru the complete spin cycle and empty could the timer control switch its all intergrated in one all the the different application s the cycles goes thru all report back to the timer control switch and when the cycle is complete the timer goes to the next cycle i f the timer is defective it well keep on going reguardless and go to the next cycle unfortunately the cost will run around 250.00 for the part good luck
Aug 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Finding an instruction manual for a Hotpoint WMA56
Click on the link below to download instructions manual for your appliance:
INSTRUCTIONS FOR INSTALLATION & USE for the AQUARIUS RANGE WMA56
Do not forget to rate the solution.
Thanks.
Mar 02, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WMA56 - Puts holes in washing
could well be a bra wire. the easiest way to check is: remove small cover on rear bottom of machine. you will see the heater on rhs. loosen centre nut and prise heater out. shine a torch down the hole and turn the drum slowly and any foreign object should be apparant
Jun 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
377 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
