Question about Philips CDR795 2-Disc CD Recorder
LG DR6921W The cd draw won't open.The display is now saying open but nothing is happening.I can't see a little pin hole relase hole anyway.
Unplug the power cord, then hold the fast forward and fast reverse while plugging the power cord.
Posted on Jul 11, 2008
Rx300 2003
see if there is a little hole on CD player about the size of paper clip. If so push something stiff in the hole will relase a stuck CD
May 12, 2014 | Lexus RX 300 Cars & Trucks
Cd drive xhnge
On the front of the CD rom there is a small pin-size hole, carefully put a drawing pin into the hole and it will open the CD drive manually, if it doesn't read disks anymore consider replacing your CD drive
Apr 17, 2014 | MSI Computers & Internet
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
How to remove a stuck cd from a 2001 mercury sable ls in dash cd player
All Cd players have a small pin hole in the face under the opening. Get a paperclip and push it in the hole top relase the carraige and it can be manually removed
Aug 22, 2011 | 2001 Mercury Sable
Phillips dvd player disc draw won"t open help
Usually, there's a pin hole beneath the tray that come out. If there is a pin hole, get a paper clip or safety pin and insert the pin or clip into the pin hole and push. That should pop the disk tray out.
Mar 21, 2011 | Philips Electronics - Others
The disk tray will not open because I selt coffe
You can use a pin to manually open the disk tray, if you look carefully at the cd draw there will be a little hole , get a paper clip or some thing and press it in there firmly and the draw will open. try then cleaning the spill and hope for the best. hope this helps.
Dec 04, 2009 | Computers & Internet
DVD/CD won't open...when I push the open/close button it says it is opening but nothing happens....have turned it off for a while and turned it back on - still nothing
if the disc inside has jammed or there is any damage to the mech for opening this can cause the jam you can open it manually by getting a paper clip ot long needle and look to the front panel just below the draw htere is a small hole insert the paperclip end into this and push the the pin in it should go a way in this will actuat a release lever the tray shoul open for you you can check the inside mech after this it may need some grease on the draw runner. Good Luck A
Oct 16, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Cd drawer
there is a little pin hole on the front of the cd/dvd draw, insert a pin or sharp object and it will eject.
Sep 17, 2008 | Computers & Internet
CD-ROM Not responding
you can get the disc out by inserting a pin in the small hole on the cd draw, but when this happens it means the laser is failing to read the disc and the cdrom is failing, unfortunately the cdrom cannot be changed in the acer notebooks.
Nov 06, 2007 | Acer Aspire 3000 Notebook
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
Philips CDR795 2-Disc CD Recorder Logo
94 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
