Ink System has Failed. Unable to Copy, receive faxes, or print. Refer to printer documentation.
Error.0xc18a0106
Turn power off,then on again.
The above error has appeared on on C7180 Printer, I have removed the ink cartridges, turned the unit off and restarted it without the cartridges in and still receive the same message.
What else can I try
Why dont you try uninstalling this form your PC/laptop and reinstalling it again. This should help restart the printer again. Good luck and thanks for using Fixya
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide to purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off. Unplug the power cord from the back of the printer. Remove all the ink cartridges. Wait two minutes. Plug the power cord into the back of the printer. Press the On button to turn the printer on. Install the ink cartridges when prompted. If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support. If you need their contact info I can give it to you. Thanks, Lee
