1998 Subaru Legacy Logo
Anonymous Posted on Dec 24, 2010
No power to rear wheels on a 98 Forester w/ auto trans.It runs and drives fine without any noise, shifts through all gears smoothly but will not distribute any power to the rear wheels. Anyone know?
  • Anonymous Dec 25, 2010
    Replaced transfer clutch assembly with a used one along with 2 gals fresh fluid and its working great !
Anonymous
Level 3:
President:
  • Master 1,702 Answers
  • Posted on Dec 24, 2010
Anonymous
Master
Level 3:
President:
Answers
1702
Questions
0
Helped
767484
Points
5420
Just looked up the 1998 Legacy, and the all wheel drive is a constant drive system, so if you don't have any drive to the rear, there is no electrical switches or solenoids to turn the rear drive on or off the system is all mechanical, so you need to take a good look at the drive shaft going to the rear wheels, Jack the car up all 4 wheels and install jack stands under all four lower a-frames then have some one start the car and put the trans. in gear and watch the rear drive shaft to see if it is turning, if it is not you will have to have the trans-axle checked out for a bad rear drive gear, if the drive shaft is turning but the rear wheels are not you will have to have the rear differential checked for a broken ring or pinion gear, but what you may find is that the drive shaft may have a broken u-joint and that you can fix yourself, pay very close attention to were the drive shaft attaches to the trans-axle and the differential.......i hope this helps let me know if there is any thing i can help you further with.
1987 saab 9000 turbo transmission
bad pressure plate or stuck throw out bearing.
1999 dodge ram 1500 5.2 liter, auto, 2 wheel Trans ran perfectly ...then stopped shifting from second to third. wouldn't change gears, even manually. i checked all connections into trans, checked trans...
1999 dodge 1500 5.2 will not shift to second once the engine reaches normal temperture or I shift from drive to nutural and back to drive then it will work fine untill the next time I stop. filter, fluid, shift slenoid,governor sensor have been replaced.
1helpful
98 forester awd rear wheels not engaging runs fine other wise drive shafts, axles all in good shape no noises in drive train. no codes,no check engine light on
Just a thought, Check under bonnett on passenger side is a fuse that when installed dis-engages the rear drive. Remove the fuse to engage the rear drive. Sometimes people see the open fuse holder and fill the slot thinking it is missing. Truth is it is only for short towing. Good luck and have a great day.
2helpful
2answers
What does the " Power " light on the dash indicate when it is lit on my Forester 2.0 Turbo S auto ? The manual doesn`t mention it !
Do you have a switch (usually a push button) on or near your shifter labeled "Power" or "Performance"? Some cars have a button that can turn on a different shift program for the transmission, usually holding gears longer and firming up shifts. Once you locate this button press it again and the light should turn off.
1helpful
Grinding in and out of 4 wheel drive
You say 'new' truck, 09? or new used? I have had 3 Fords, 3 w/ manual trans. case, if you go into 4x4 Low range, you must come to a complete stop before shifting the trans. case to 4x4 mode, and I always put trans (automatic) in neutral before slipping into 4x4, it engages smoothly, no grinding. 4x4 high range can be put in while moving, but I would let off the gas pedal, shift to 4x4 high range, then resume accelerating. If there is any grinding going on doing it as above, something isn't right. Check the trans. case fluid level also, to make sure that's not an issue.
1helpful
1998 VW Cabrio loud humming from what sounds like the transaxle
Have you checked that the noise is not tyre noise?
Interchange the wheels front to rear (or left to right) to see if it has any effect on the noise.
Only do the test below if the car is securely chocked so as not to move, take great care not to contact moving parts!
Securely jack both the car drivewheels off the ground, then 'drive' the vehicle through through the problem drive speed/gears while listening for the noise. If the noise occurs under these circumstances you may be able to further localise the source by listening (very carefully!)with a short hose pipe held to the ear.
2helpful
2answers
98 Civic Auto Trans Slippage
you need to replace clutch pack for that gear can be ordered seperately from parts store or dealer if you want to save money call peach street auto recycling at 1800-365-2341 for a warrantied used one! also might be time for change trans filter and fluid filter could be slightly clogged but I lean towards clutch pack I replace these alot on Hondas
Top Subaru Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Oliver Street
Are you a Subaru Expert? Answer questions, earn points and help others
