I'm installing ubuntu linux 8.04 on my acer laptop - partition question
I'm at the point where I'm selecting the partition size. My computer says (on the left side of the screen: /dev/ 10% and on the right side: Ubuntu 8.04 90%. Which is the partition size of Ubuntu 10% or 90%.....or should I use the "largest continuous free space" option. I would like Ubuntu to take up most of my hard drive instead of vista.
Also can I resize later if I decide to dedicate 100% of my hard drive to Ubuntu?
  • bwinter Jul 05, 2008
    Good point. I have barely used the computer so it should not take long to defrag it. Can I cancel the install at this point by hitting the "back" button?
    What option should I choose for Ubuntu to take up about 70% of the space on my hard drive?
    Thanks for the info. I'll try out the Live CD before installing Ubuntu.
  • 13,433 Answers
Yes you can resize your drive later, before installing ubuntu on the same drive with another operateing system you need to defrag the existing drive, and then resize the partition and then install the ubuntu.
Posted on Jul 05, 2008
  • Ekse Jul 05, 2008
    You can also try ubuntu from a live cd which doesn't require you to install anything.
  • Ekse Jul 05, 2008
    posted by Ekse on Jul 05, 2008
    I think you rejected my solution a bit too fast.
    anyways
    Yes you can cancel your setup at this point your vista should still work and you can do that.
    Comment by Ekse, posted on Jul 05, 2008
    to get it to use 70% you would need to configure the partitions manually.
    read here
    http://www.psychocats.net/ubuntu/partiti...
Uninstall os linux ubuntu 13.10 from my laptop
Are you dual booting? Windows and Ubuntu? What version of Windows? You maybe able to reclaim the space by using the Disk Management (right click "My Computer" select Manage then select Disk Management). In there you will see NTFS for your Windows partitions, and something like Unknown for the linux ones, you can then delete the linux partition and possibly extend your NTFS partition to use the free space (depending on version of windows).
If this is a standalone Ubuntu install, you should be able to just use the installer disk for another OS and boot it to reformat the drive.
good luck!
Jan 10, 2014 | Computers & Internet
I own an ACER 4315 Laptop computer MS2220 Atheros AR5BXB63 with Windows Vista Home Basic. I'd like to partition the hard drive to run Ubuntu Linux. However the Ubuntu 7.04 Liveboot CD not recognized as a...
Hello there.
Nice to see more people trying out Linux :-)
From your description it sounds like the CD image you downloaded is not bootable. What i would do is scrap that CD and try the following, this is a guide that explains step by step how to take the downloaded .ISO file and burn it to CD, so that the computer can boot from it (known as a bootable CD).
Please click here for the information.
As Ubuntu has a partition program as part of the installer, you can use this to resize your Windows partition and install Ubuntu in the free partition left over.
This should get you setup in no time :)
Hope this helps.
Jul 04, 2008 | Acer Computers & Internet
Tip
How to install/dual boot Linux on your mac
you need to <br /> <br /> A) download a copy of linux (i always use ubuntu) <br /> http://www.ubuntu.com/desktop/get-ubuntu/download<br /><br /> B) burn that copy of linux to a CD<br /> (to do this you need to go to your disk utility app and click burn image to disk and than select the iso you chose, using other software the option will be something like "create mountable disk" OR "burn bootable image")<br /><br /> C) boot to that cd--- to do this you put the cd in and reboot your mac while holding the 'C' key <br /> <br /> D) open the partition editor and create a partition on your hardrive the size that you want linux to be (idealy replacing the main partition on your computer not one of the smaller boot partition)<br /><br />*Optional- If you are planning on dual booting do not replace the main partition completely instead create a new linux partition from the main partition's free space additionally if you are dual booting and using Leopard or later you can use the bootcamp app to create a partition than use the linux partition editor to format the bootcamp partition to free space and than install linux on it<br /> <br /> <br /> E) once you have the partition made simply follow the initial instructions to install there will be an installer app that replaces your now free partition with linux.<br /> <br />*if you chose to dual boot to access linux simply hold the 'Alt' key when booting up and than highlight the linux/windows HD<br /> Enjoy<br />
on Mar 02, 2011 | Computers & Internet
I have downloaded Ubuntu Linux 12.04 and am running it under wondows xp sp1. How can I delete windows and just run Ubuntu ?
Here is what you need to do:
1. Open 'GParted'. From the menus: System -> Administration -> GParted
2. Right click on the ntfs partition and select 'delete'
3. Right click on this deleted partition and select 'Format to' and select ext3. This should accomplish what you want.
If GParted is not installed, then open a terminal window and type
Code:
sudo apt-get install gparted
And then proceed with steps 1-3 specified above.
PS: Backup any data you need from the WinXP partition before you do this.Alternately, instead of formatting the XP partition to ext3, you could do this:
Using gparted, as described above:
Right click the XP partition and click delete.
Right click the Ubuntu partition and click resize
In the resize dialogue, change the settings to that it is as big as possible.
Click apply changes.
This is riskyer, so BACK UP EVERYTHING!!!!!! I do not take responsibility for lost data.
This however will be closer to "unpartitioning" the drive, what was suggested above will still result in it being split into two partitions, they will just both be linux partitions.
Oct 27, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Reformat laptop with Linux
First you need to choose a linux distro, I suggest ubuntu since it is the easiest by far.
Steps for installing ubuntu -
1. go to http://www.ubuntu.com/download/ubuntu/download and follow the directions to burn a live cd
2. restart your computer with the live cd in the cd drive
3. you can choose to try ubuntu, test it out for a bit, and then install it from inside ubuntu, or you can install it directly from the menu you get when your computer boots up. When trying ubuntu, you can also mess around with the built in partition editor ( there is an option to format the whole drive when installing so you don't have to worry about formatting before installing)
4. Just follow the instructions and install, and then enjoy :)
Jul 06, 2011 | Acer Computers & Internet
I will ask if i can download windows 7 on linux acer aspire 4738?there will be a problem?
there won't be any problem as far as Windows and Linux, but this is a fairly involved procedure.You'll first need to create a Windows partition on your hard disk in NTFS file system format. Otherwise,Windows might overwrite / erase your linux installation when Windows 7 installs.
make the windows partition the "Primary" or "Boot" partition.
When Windows 7 installs, it may ask if you want to delete the linux partition.Answer "NO" to this.
The next concern is which operating system will boot by default,Windows or Linux.
I had no problem doing this with Windows Vista, and whe Vista booted,it listed a choice of operating systems to boot,and I would select either Windows Vista or Ubuntu Linux.
Apr 03, 2011 | Acer Computers & Internet
How can I install Linux on an old Macintosh iBook? Perhaps DSL??(damn small linux)
DSL does not contain all of the drivers needed for the computer to work well. Try Gentoo linux, or Arch linux.
Mar 02, 2011 | Apple Computers & Internet
How to Install both XP and Linux?
I would install XP 1st then Open suse or Ubuntu. When you install either of these linux OS's ensure you install to another partition other than the windows one. Both installation routines will allow you to format the drive to the linux ext2 format and automatically install a boot manager (usually GRUB) which will allow you to select the OS you wish to boot.
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
