Question about Dryers
Dryer motor spindle mounts, which are made of hard rubber, are worn. There is a lot of play and the machine vibrates very loudly. There isn't an obvious way to remove/replace the mounts. Any suggestions would be appreciated. It is an Amana dryer model LE8607W2. Thanks.
  • ccwh Jul 07, 2008
    I meant the spindles on the actual motor. I've checked around on the web and it seems that the bearings on the motor are worn out. Some of the symptoms were a noisy dryer (even after replacing the drum support rollers, drum glides, belt and blower wheel). I had to help start the drum with a push... Is there a way to replace the bearings?
    Thanks!
  • Kirk Severs
    Kirk Severs May 11, 2010
    There are drive wheels that allow the drum to ride on them, those have bearings in the middle of them and can be removed/replaced. The bearings will wear out and make a loud racket. Are the 'mounts' you refer to the wheels I am talking about?
    Scholar:
  • 170 Answers
Some motors are not accessible to replacing any parts. I would guess that many of today's dryers are that way, not sure about yours. It sounds like things are too tight on your drum/belt/motor assembly because of your having to give the drum some help. There should be some kind of adjustment on the drive wheel that the belt that goes around the drum starts on. If you loosen the adjustment enough to let it 'breathe' a little and not be so tight, that might be the genesis of your situation. As far as replacing the bearings in the motor, you probably will have to replace the motor since as I mentioned many of today's motors have no user accessible parts to replace.
Posted on Jul 07, 2008
It is makeing a lot of noise
Hello. You didn't provide a brand/model number or the type of noise the unit is making. If the dryer is making a screeching noise, it's probably the idler pulley(spring-loaded tensioner pulley that keeps the drum belt tight so the electric motor can turn the drum properly) being worn out or binding up due to lint build-up in the dryer. However, if the dryer is "thumping" loudly, most likely it's a worn out support roller either on the front or rear bulkhead. They're made of hard rubber and can become malformed due to wear/age causing a rough movement of the drum as it spins.
Aug 18, 2015 | Dryers
My machine is 2 months old and makes a horrible thumping noise during the spin cycle. Also the fabric softener compartment won't drain water
Ugh the thumping noise during spin may mean bad agitator spindle where the splines have been damaged or perhaps a damaged transmission spline, at other times it could be due to bad counter weights . check below
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 29, 2015 | Washing Machines
Whistling
Jul 22, 2014 | Whirlpool Washing Machines
Spin cycle is loud
Jul 01, 2014 | Whirlpool WTW5550X Washer
Loud grinding noise when drum turns
Apr 20, 2014 | Asko Washing Machines
Loud extremely
Dec 18, 2013 | Asko W6441 Front Load Washer
I have a LG WM3987HW combo washer dryer that is also making the roaring noise on spin cycle
By the way my advice is free cuz God is good!
GRINDING NOISES:
The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it.
May 31, 2012 | LG WM3987HW 4.2 cu.ft. White Front Load...
Squeaky basket and loud vibration when in spin cycle.
Bearings worn, belt loose and probably motor brushes.
May 17, 2012 | Kenmore HE3T Washer
I have engine vibration in 2004 Trailblazer. Vibrates when at a stop. Some vibration when in nutrel, but really bad when put into drive. Had motor mounts replaced. Replaced the plugs and coil packs. ...
Good call on the engine mounts, this problem has had a lot of TB owners scratching their head. Hope you used genuine GM mounts, aftermarket mounts tend to crush too much sending you back with the same problem you started with. With aftermarket mounts, the engine will not be as high as needed, the rubber isn't as stiff. Seen this many times. The other thing to check is you tranny mounts. Engine and tranny mounts are usually the culprit with vibration while in gear and stopped with TB's. What type of plugs did you install? Have you cleaned your throttle body?
May 30, 2011 | 2004 Chevrolet TrailBlazer
My maschine is vibrating alot
Checck for play in the motor shaft , the jar spindle. If so you must remove the shaft to be reset with new bushes so that there is no agitation from the play.
Being high speed a small play can cause a lot of vibration and the spindle must work tight.
Sep 18, 2010 | Omega 1000 Juice Extractor
Dryers Logo
161 people viewed this question
Top Dryers Experts
