Not receiving signal that would allow the monitor to display from computer
  • DANNY21 Jul 05, 2008
    I DON'T UNDERSTAND WHAT YOU ARE SAYING...........
    Genius:
  • 2,785 Answers
Plz resit the ram if the problem is not solved than *********** board display adapter has problem
Posted on Jul 05, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Jul 08, 2008
    plz open the side cover and resit your ram(you have to remove the power cord before opening the side cover).
    after that also you dont get any pic than your motherboard needs to be repaired
Packardbell imedia
Hi paul,
1. check signal cable from pc into monitor and try to use other signal cable also do try into other monitor if prob cant solve.
2. your imedia include with graphic card? If has a graphic card try use other good graphic card to test the display run or not. If cannot.
3. Try make some cleaning into your ram, Test your ram one by one because sometime no display appear because of broken ram.
Try check this 2 site to other solutions..
Thanks..
1. How To Test Computer Monitor That Won Display Or Is Not Working
2. Fix Your Computer Monitor When the light is yellow or amber not green (try this one)
Good Luck.
Jan 19, 2014 | AMD Computers & Internet
Tip
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
Monitor gets signal from computer but doesn't display. Monitor will display message that says no signal when unhooked from computer but will not display menu
Sound like it could be corrupted video driver. I would try holding down the F2 key to reach the system bios. Select vga for the video display if in the bios...then save and restart. If you can't get to the bios screen, try F8 and see if you can get safe mode...if so...it should allow pc to use the vga driver and thus hopefully display will work. If you get in and see windows, then you most likely ned to remove the display driver and reinstall it.
If still not working, try hooking monitor to another video port. Might need to get a conversion adapter to fit to vga port, or dvi port or whatever else you might see.
Jul 06, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Blinking with no signal video displayed,also blinking picture after started windows
"no signal" means exactly that. You monitor is not receiving signal from your PC. Recheck the video cable on both the monitor and the PC, make sure they plugged in properly.. Also try another monitor if you have it, and if it works with that monitor than more likely you have a frequency sync problem. In this case, using another monitor that works, and try resetting the video to basic 60Hz. In Windows, Start->Control_Panel->Display. Change the display resolution to the lowest, apply the setting, then change the monitor back to the questionable one. If it still doesn't work, then your video processor on your monitor is bad; RMA it if it's still warrantied.
Blinking picture problem, try suggestion above.
May 30, 2010 | ViewSonic VX1935wm LCD Monitor
The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Mar 03, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
When my monitor comes on it displays a blue box that just contains the word analog and then the box goes away
It is not receiving a signal, check the connections. Also most monitors have dual connections, one for analog and the other for digital. If yours is using the DVI Digital connection then you need to switch you monitor to that input. There is usually a button on the front that will allow you to switch between the two, it is usually an arrow pointing to a box.
Jan 26, 2010 | LG W1934S-BN 19" Monitor
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
NO SIGNAL What do I do?
These messages are normal when the computer truly goes into suspend mode or loses the video signal (such as when the computer is suddenly turned off).
If the monitor displays any of these messages when the computer should be displaying video , do the following items until an image from the computer appears:
1.
Ensure the computer is really sending a video signal. To bring the computer out of suspend mode: move the mouse, press the spacebar, and press the suspend button on the keyboard twice (the suspend button has an icon that looks like a quarter moon).
2.
Ensure the video cable is connected (and connected to the correct video port).
3.
If you are trying to view video from a set-top box, DVD player or similar device, use its menu system to set the proper video output channel so that it matches the video connection are using. For example, if the monitor is connected to a satellite receiver via a second HDMI connection on the back of the receiver, select HDMI-2 (or similar) using the remote control for the receiver.
4.
Turn off the monitor using the monitor's power button and then restart the monitor.
5.
Cycle the power on the monitor as follows:
1.
Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
2.
Unplug the power cord.
3.
Wait 5 seconds.
4.
Plug in the power cord.
5.
Press the power button on the monitor to turn on the monitor.
One of two things happens:
1.
The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
2.
The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution.
6.
Adjust the Windows display resolution to a setting that is compatible with the monitor:
NOTE: The native resolution setting for your model of monitor can be found in the Monitor User Guide, the monitor's product packaging, and product specifications.
1.
Restart the computer and press F8 repeatedly after the first logo screen.
2.
Select Safe Mode .
3.
Windows should open showing a Windows desktop with lower resolution and fewer colors.
4.
In Windows Vista, click Start , Control Panel , and click Adjust Screen Resolution in Appearance and Personalization.
In Windows XP, click Start , Settings , Control Panel and then double-click the Display icon and select the Settings tab.
5.
Move the slider bar until the native resolution for the monitor is set, click OK and restart the computer.
6.
If the native resolution is not available from the slider bar, click Advanced Settings , click List All Modes (from the Adapter tab), select the resolution, and click OK .
If the native resolution setting is not available as a selection in Windows, you can temporarily use 1024 x 768 to complete these steps. However, you should update the graphics driver on the computer. Updating the graphics driver can provide more display resolutions to Windows; possibly including the native display resolution for the monitor.
Check for nVidia video driver updates at nVidia Home Page (in English).
Check for ATI video driver updates at ATI Home Page (in English).
Check for S3 video driver updates at S3 Graphics Home Page (in English).
Check for Intel video support and downloads, Intel Downloads (in English).
If you own an HP or Compaq computer, HP hosts video drivers and some video driver updates at the HP Software and Drivers site (in English)
7.
Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jun 15, 2008 | HP PAVILION A6230N DESKTOP PC
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
