Disk error message when trying to view dvd - Televison & Video
  • 3 more comments
  • pertyekeyte Nov 03, 2008
    I get an error that says NO DISK even after inserting the cleaning CD, I had just bought the movie I was trying to see, and even tried playing some rentals but the problem persist..... Is there a way to fix it?
  • m_sadr Nov 16, 2008
    Everytime I put a DVD (original and legimate) geeting the NO DISK error??
  • sweets73 Dec 15, 2008
    the little green light by the other keys keep blining too and the a no disk error comes up...hope this can be fixed...
  • sg29651 May 17, 2009
    I have the same problem with the "error" message when tryin to play movies too. But when I put in a music disc it will play it fine. Can anybody help figure it out please??
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this a store bought DVD movie or a DVD that was buned on a computer?
It's a dirty drive motor. I have the same unit with the same error. Remove the screws underneath and the unit will open up. Flip the motor assembly upside-down and remove the sticker. Spray contact cleaner in all the holes and turn the spindle by hand. Take a small flat blade and pry off the black top. It should slide off with minimal resistance. Remove the two micro screws and take the motor out of the assembly. Again, spray contact cleaner in the holes and spin the motor by hand. Reassemble and watch your movies.
Posted on Mar 16, 2009
Was trying to play a rental DVD, tried several and same result. Tried to insert a cleaning DVD but it wouldn't play either. Can hear it load but seems to be a problem in reading the DVD.
Posted on Jul 06, 2008
I have a Panasonic VHS-DVD player/recorder model DMR-ES35V. I was recording and playing back at the same time using a DVD-RAM disk (using the time slip feature). After about an hour of viewing I got an...
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Oct 21, 2010 | Panasonic DMR-ES35VS
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
How do I prepare a disk for viewing on a dvd player? when I put the disk into the player, I get a disk error message
In order to "finalize" a DVD for use in a DVD player you will need to use a software program on your computer. Look to see if the "burning" software you used has an option to finalize the disk.
If not, one popular program is Nero...
They have a free version which may suit your needs...
http://www.nero.com/enu/downloads-nero9-free.php
Sep 12, 2009 | Roxio Easy CD & DVD Burning
I want to finalize a dvd-rw to write to a dvd disk for viewing?
to finalize you must plug in your AC power supply. then finalize your dvd.
May 03, 2008 | Panasonic VDR-D150EF-S DVD Camcorder
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd is unable to read disk that i recoreded on the lg dvd recorder
It would be nothing to do with the TV.
DVD RW discs only last for so long if you have re-written to them many times they may be just worn out. Or is it with all RW discs?
Are you trying to watch them on the same player you recorded them on or is it a different DVD Player you are trying to watch them on?
Feb 17, 2008 | Televison & Video
Disk Error when Finalizing DVD
you just need to replace optical pick up of the set. It must be costing abt rs 6500/-
Aug 24, 2006 | Panasonic Palmcorder VDR-M30 DVD Camcorder
Televison & Video Logo
472 people viewed this question
Top Televison & Video Experts
Electro Med Services...
