Question about HP Office Equipment & Supplies
I have an hp psc 1300 series all in one. I have just got a new pc with windows vista and it will not load the software for the printer/scanner
  • alan_pearson Jul 07, 2008
    Sorry, too complicated for me. I will get a new printer
    Novelist:
  • 150 Answers
Try this link = HP download =
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=61956&lang=en&
1) Make sure you select the right version of Windows:
32 bit or 64 bit, depending on your installation.
2) Uninstall the failed driver. Check the device manager for
existing drivers, see if they are malfunctioning and
remove them using the device manager.
3) Follow the driver installation instructions exactly, some
USB devices must NOT be plugged into the machine until
AFTER the driver is partially installed,
This is because Windows plug and pray often mis-detects
the USB device and installs the wrong generic driver, which
then prevents the correct driver from installing properly.
5) Check your user settings and privileges, make sure that
you actually have full administrator rights.
6) Check the local policies, make sure that your user group
is granted printer installation rights.
7) It is not unusual for HP drivers to be flaky, because HP
has been at the bottom of the quality food chain for years.
After having a terrible experience with an HP Deskjet 1000c
large format color printer, which cost me over $1100 at the
time, I avoid HP like the plague.
Most of HP peripherals have only minimal controllers
inside, relying heavily on the PC and windows to do most
of the rendering computation, thus slowing down your
system and requiring very bloated device drivers.
These drivers are often written abroad or within sweat houses
in the US, employing low wage Russian Immigrants.
Once released, the drivers are never updated nor supported
by HP. At least that is what my research discovered with
my 1000C.
This is not the company which Bill Hewlett and David Packard
started in the 1930's, 90 Billion in revenue not withstanding.
Good luck
Martin.
and install
Posted on Jul 05, 2008
  • Martin J Stadler
    Martin J Stadler Jul 08, 2008
    Hi, Don't give up just yet,
    Let me know what kind of computer you have
    and what kind of operating system:
    Computer:
    Intel or AMD ?
    32 Bit (such as Pentium II, III or IV) or 64 Bit (Such as Core 2 Duo)
    Operating system:
    Windows 9x (95, 98 or millenium)
    Windows 2000
    Windows XP (Home or Pro)
    Windows Vista ? (32 bit or 64 bit)
    etc.
    I will do my bes to walk you through it,
    Martin
    President:
  • 1,257 Answers
Here is the solution :
Reference guide
Good luck
Thanks for using fixya technical serivices.
If you need more help just reply with a comment.
  • Deeps . Jul 05, 2008
    Installing the Printer Driver Located in Windows Vista
    The driver solution for this product is included in your Windows Vista operating system and is already on your computer.
    There is no need to download anything
    . Follow the steps below to quickly and easily get your product working with Windows Vista.
    Installing the printer driver
    1. Verify that the printer is turned on.
    2. Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
    3. A
      Your devices are ready to use
      window might display on the screen. If the window displays and does not close automatically, close the window.
    4. Print a test page to verify that the printer is working correctly.
    Using the basic printer functions
    Printing
    1. Open the document to be printed in the software application in which it was created.
    2. Click
      File
      and then click
      Print
    Scanning
    Scanning with Windows Photo Gallery
    1. Click the
      Start
      ) icon.
    2. Click
      All Programs
    3. Click
    4. Click
      File
      and then click
      Import From Scanner or Camera
    5. Click
      Import
    6. Click
      Scan
    Scanning with Windows Fax and Scanning
    NOTE:
    This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
    1. Click the
      Start
      ) icon.
    2. Click
      All Programs
    3. Click
    4. Click
      New Scan
    5. Click
      File
      and then click
      Scan
    Scanning with Paint
    1. Click the
      Start
      ) icon.
    2. Click
      All Programs
    3. Click
      Accessories
    4. Click
      Paint
    5. Click
      File
      and then click
    6. Click
      Scan
    Genius:
  • 1,847 Answers
  • Legin Varghese
    Legin Varghese Jul 05, 2008
    download this file ...
    ftp://ftp.hp.com/pub/softlib/software5/COL10592/oj-30803-1/ep_rub_w01_ENU.exe
    and the installation procudure is ..
    Software Installation instructions:
    1. Click the Download now button.
    2. Choose Open to start the download and then follow the on-screen instructions to extract the installation files.
    3. Click Start and choose Run.
    4. Click Browse and navigate to the folder where the installation files were extracted. By default, the location is "C:\temp\HP_WebRelease".
    5. Select Setup.exe and click Open.
    6. Click Ok and then follow the on-screen instructions to start the installation process.
    7. When the installation is finished, connect the cable between your HP all-in-one device and your PC, and turn on your HP all-in-one device.
  • Legin Varghese
    Thanks for using Fixya.
  • 426 Answers
Have you downloaded the vista divers? if not hang tight and i willget you a direct link
  • Lee N.
    Lee N. Jul 05, 2008
    see if you can get a model and/or serial number, this should be located on a tag on the bottom or rear of the printer Thank You
Ever since I've changed my Pc into Vista I cannot use my printer/scanner HP PSC 1500 series
Go to Hp support website, enter model number update drivers for VISTA operating system, if available.
Jan 22, 2012 | HP PSC 1510 All-In-One InkJet Printer
Unable to load software for HP PSC 1400 to Vista
Download Vista drivers from here.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_pagetype=s-002&h_query=PSC+1400&submit=%C2%BB
As the 1400 doesn't appear in the list so make sure you check the model number.
Most of the drivers for the series are the same as will be the software.
Sep 06, 2009 | HP PSC 1401 All-In-One Printer
Running vista now. it has drivers for the printer but scanner and copier drivers are on setup disc as the disc does not support the new opperating system it will not read the disc so just wondering if...
If you don't use the HP software (i don't on my 1300 series) Uninstall all of it.
Then go to device manager and remove the printer,then reboot(while rebooting unplug the printer from the computer) and then once the computer is up, plug the printer to the computer, it will find the printer and let it search for drivers, it should find vista drivers for the 1300 series
if this may not work try this additional steps:
Go to Control panel>printers>Right click on the printer and select properties then ports and see if it set as a USB port if not you may have to create one
Aug 16, 2008 | HP Office Equipment & Supplies
Hp psc 1100/1200 all-in-one does not scan with vista..
I had the same problem. Click Start, Windows Photo Gallery, from that screen, you can select import from scanner. The 1200 series printer should be a choice to select. You are then able to preview the image or document, then press scan. I found this out through the HP support website.
Aug 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Need to install printer HP PSC 1500 all-in- One series
i lost the software of psc 1500 all-in-one can you help me?
Jun 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
Vista
Your problem seems like a driver issue. try to down load complete driver for windows vista and install it.
Apr 19, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer HP PSC 1400 to run with Vista program
You will need to go to the HP support site,
http://welcome.hp.com/country/us/en/support.html
Find your specific printer, and download the driver for Vista. Should not be a problem after that.
» HP PSC 1401 All-in-One
» HP PSC 1402 All-in-One
» HP PSC 1406 All-in-One
» HP PSC 1408 All-in-One
» HP PSC 1410 All-in-One
» HP PSC 1410v All-in-One
» HP PSC 1410xi All-in-One
» HP PSC 1417 All-in-One
Feb 23, 2008 | Office Equipment & Supplies
Seeker5211
Seeker5211
