Question about Lexmark Office Equipment & Supplies
Printer does not print anything other than "test Sheet & Alignment sheet" When i try to print from a file, my brand new Lexmark printer generates only blank sheets. I've tried un-installing & re-installing the software. Also I've ensured my printer is set as default printer. The Error message appearing on the printer window, say's I have an " Alignment Problem".The troubleshooting guide directs me to ensure the tape has been removed, & to re-insert the cartridges, then press the "check" button.
    Genius:
  • 2,785 Answers
After consulting your manual and done as it says the problem is not solved then you should ask your vendor for help as your printer is on warranty
Posted on Jul 05, 2008
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
May 26, 2015 | Canon MX340 AllInOne InkJet Printer
If I schedule a print for my Lexmark X83 it feeds one sheet of paper straight through to the tray but does not print anything. No alarms anywhere on system. Same thing occurs if I ask for test print or...
Sounds like a clogged print head. In the lexmark printer software there should be a maintenance tool where you can try and clean the print heads.
By the same token the X83 is about 10 years old and well past the life cycle of most ink jet printers so if the troubleshooting tools don't get it back in order, it will be cheaper to replace than to repair.
http://www.lexmark.com/AP/service/info/multifunction/4403.pdf
Jul 09, 2011 | Lexmark X83 All-In-One InkJet Printer
Printing is offset
you need to run a printer alignment page like you do when you put in new cartridges.
Aligning the
􀁺 Ensure that the Inner Cover is closed.
􀁺 The Print Head can also be aligned from the printer itself.
Feeder.
times.
Feeder.
See “Opening the Printer Properties Dialog Box Directly from the Start Menu” on
page 28.
remember if my answer was of assistance please leave a positive rating and a testimonial.. THanks Good luck
Mar 28, 2010 | Canon Pixma iP3000 All-In-One InkJet...
The printer is saying printing started and printing complete but yet their is nothing printing at all; the print jobs are collecting in the queue. Printer keeps telling me alignment problems when I...
It sounds like it is trying to print an alignment sheet, so that the printer can then scan the sheet, and see how bad it is off, if any. Start here.
Look in your user manual to see how to force an alignment check. There is also usually a setting in the driver as well (icon in the system tray near the clock).
Nov 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
My printer wnt work i boght new ink but it wont print
Hi
whenever you put new ink cartridges,your printer prints an alignment sheet
if your printer isn't printing,
one of the concern could be that it didn't print the alignment,uninstall the cartridges and put them back again.
also try printing an alignment sheet using the printer driver located in the control panel,printers and faxes
once you go into the properties and click on the device settings and click on service this device you will get option to print alignment sheet
this should work
Jul 17, 2009 | Dell 926 All-In-One InkJet Printer
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
Mar 07, 2009 | HP DeskJet 920c InkJet Printer
Cant install lexmark x2600 on windows vista
You need to install the Vista version. Goto this site-download the driver-install-enjoy!! http://search.lexmark.com/printer/US/en/12L1685.html
Dec 17, 2008 | Lexmark X2500 All-In-One Printer
Alignment sheet prints---cannot print anything else
u will have to first scan the alignment paper in your scanner this will solve your problem
Nov 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Color problems with Lexmark X75 printer
hi ..
please get new color cartridge tested with other Ok printer
then from your printer get cartridge alignment with clean cartridge utility
Apr 08, 2008 | Lexmark X75 All-In-One InkJet Printer
I can't get my printer to printer from my computer
You also have to place the test sheet on the scanner bed and scan it so that the printer can take a look at the alignment settings.
Feb 24, 2008 | Lexmark All-in-One Printer with PictBridge
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
