Question about Kitchen Ranges
The burners in the gas oven are producing uneven flames and creating soot - ie. blackening the doors and walls of the oven? There seems to be one screw on the left hand side of the burner - can we take the burner out to fix it?
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Yellow flame and black soot is an indicator that the flame tube is being starved for oxygen. Where the orifice injects the fuel at the base of the flame tube you should find a movable air adjustment shutter that is usually held in position by 1 screw. This screw may have loosened and allowed the shutter to close off oxygen to the flame. Below is a link to a page that shows an oven burner to enlarge image pn1015233 and observe bottom end. Rotate shutter any direction until a nice blue flame appears but is not "blowing" off the burner tube. Tighten screw to retain position.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Sep 02, 2010 | Pitco Frialator 35CS Deep Fryer
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Viking range creating a lot of soot?
This is a definate sign of improper gas/air mixture. The flame needs to be even and blue.
Make sure the orifice is clean. Usually the burner (oven) will have a "Door" or "Shutter" type adjustment where you can turn it and add or choke off air. This is the primary air supply. The secondary air supply is usually supplied by louvers or vents close to the burner area.
Mar 13, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Magic Chef LP range produces soot whenever oven is on.
The vent (shutter) allowing air to mix with the gas has shut. Access the burner with the oven off, of course, and look for the shutter (a sliding 'door'). It usually has one screw holding it n place and an elongated slot to permit adjustment. It may also turn. Since your burner is producing soot, you need to open the shutter more. Loosen the screw and slide the shutter open more. Turn the oven on and look for a nice blue flame, and one that doesn't run too far over the burner. Keeping in mind that everything there will be hot when the burner is on, and also for a long time after it is off, you can use a long-bladed screwdriver to push the shutter back and forth to get the flame you are looking for. If the screw is loose, a gentle tap will be enough. When you are see that optimum blue flame and you are satisfied, let the oven cool off for an hour or so, and final tighten the screw--making sure you haven't moved the shutter much when tightening. If this doesn't work you have a bigger problem and need to call a service person. Your local gas company sometimes will direct you to a person.
Dec 08, 2008 | Kitchen Ranges
Side burner on Jennaire grill
The soot stains come from the air mixture, that will show too much yellow flame tips, just adjust the air intake, too have an idea how much to adjust it, and also it wouldn't hurt to clean the flames holes by sticking a pin. Alos make sure you have the right fittings converters. It's the grill LP Gas or Natural?
Hope this help
Eddie Rentas
Tupper Lake NY
Aug 01, 2008 | DCS Double 30'' Grill Cart Side Burners in...
Kitchen Ranges Logo
284 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
