Question about Lite On LITE-ON SOHC-5236V COMBO BK OEM (SOHC5236VBKOEM) Burner
Urgent!!! Cannot open CD/DVD drive
I can't open this CD/DVD drive. What should I do? Thx~
  • Lite On Master
  • 2,794 Answers
Do you have a paperclip handy?
Only do this if your trying to eject. On the left side of the drive below the CD tray is small hole. Unravel the paper clip and stick it in the hole. This will eject the tray.
Otherwise restart you computer and see if that frees up your drive.
Posted on Jul 05, 2008
Asrock doesn't detect my sata hard disk because I don't have asrock cd support
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 20, 2011 | Asrock K7VT6 (K7VT6 RAID) Motherboard
My pc is 2 months old and i cant burn audio cds it just burns the covers of the album im trying to burn ive replaced the cd drive twice any ideas anyone thx
what program you use to burn the CDs?
i suggest you to use NERO.
its highly recommended.
please vote my answer so i can give more next.
Mar 07, 2011 | Enlight Combo (5601908) (Beige) (5601908)...
I CANNOT OPEN MY DVD DRIVER ON MY TOSHIBA NOTE BOOK
I have never worked with a toshiba notebook.However every DVD/CD driver has a small pin sized hole on the front of it .This hole is sort of a manual switch.If getting the drive open is urgent, insert a pin in the hole and press gently, the drive should pop open.Get your drive checked though.Most likely it's the motor which has failed.Within warranty periods it's a free replacement.
Dec 31, 2009 | Toshiba Satellite A100-S8111TD Notebook
Problem w/ dvd drive in dell xps 1530
The drive may be damaged but to eject the cd manually turn off the power and there is a small hole around the face of the drive. You can use a straightened paperclip to push in the hole and it should eject the cd. Let me know if you have any questions.
Thx
Jul 31, 2009 | Dell (0F146) Internal DVD Drive
Dvd ram can not read cd.
I had the same problem, this is what worked for me.... I opened the cd/dvd drive on the side of my laptop and gently cleaned the small laser and hey presto it worked, can now erase,read and play my discs.Give this a try it only takes a few seconds. Good Luck
Apr 20, 2009 | Acer Aspire 4315 Notebook
MATSHITA DVD RAM UJ-850S Device Not Even Shown
Try a Google search for the driver. I got my printer driver that way. Prints just fine.
Feb 14, 2009 | Computers & Internet
DVD drive on laptop doesn't read
ur lens needs to be cleaned by lens cleaner...
Dec 01, 2008 | IBM ThinkPad T23 2647 Notebook
Cs 3 won't open on a dell studio 15
help the program command of cs# cannot be opened.
Please give the solution is urgent.
Thank you very much.
It is urgent.
Oct 16, 2008 | Adobe Computers & Internet
My xbox 360 cd drive keeps on opening and closing.
Your having a dvd drive problem Im taking a guess but i have fixed many like this before. What you need to do is take your xbox360 apart. You can find a video how to do this on our site http://www.xboxmodshop.com next you want to remove your dvd drive take out the four screws on the bottom and remove the top cover. Now make sure your looking at the spindle where the game rest in the middle of your spindle you will normally find two magnets, but in your case your probably wont. Yours are probably stuck to the top of your drive cover. You need to remove them and superglue or epoxy them back in the middle of your spindle.After completely dry put everything back together it should play normal.I recommend a inter-cooler so this wont happen again.
Thanks http://www.xboxmodshop.com
Oct 11, 2008 | Microsoft Xbox 360 Console
Lite On LITE-ON SOHC-5236V COMBO BK OEM (SOHC5236VBKOEM) Burner Logo
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
