Panasonic NV-DS37 Camcorder Logo
A
Anonymous Posted on Dec 24, 2010
Camera says "Please e-operate after pushing reset
Level 3:
  • Panasonic Master 17,130 Answers
  • Posted on Dec 24, 2010
Panasonic Master
Level 3:
Answers
17130
Questions
0
Helped
3635286
Points
52372
Remove the battery and keep aside for about 15 minutes. Now after inserting reset the camera., if the fault occurs., remove the tape and use a hair dryer to blow into the tape tray section/drum section.
It is possible that the dew sensor is working to indicate moisture, if so the heat will change the fault.
Also if the hall IC's within the drum is faulty the drum will not move and so will indicate a fault-- service.
  • manjvas Apr 04, 2011
    dear stan,
    i had this problem too on my panasonic nv-ds37 . you remove the tape and rewind it by hand tight and play. this is a problem with loose winding of tape. hope it helps you,
    [email protected]
Why does shutter error message appear when button pressed?
If the shutter has 100K operations then the camera may be due for a replacement (not worth repairing).
Please make sure you have a fully changed battery in the camera. If the camera does not have a battery icon anywhere showing a low or dead battery then you have a camera that should be sent to a Nikon Authorized service center. They can clean and repair your camera. They will; QUOTE the repair before you pay. All you are out is shipping costs.
" please re-operate after pushing reset button".
Could you please provide more details such as Camcorder model and company? Thanks.
tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 • Televison & Video
Camera can't operation
nocko pradika try to do factory reset by settings, it will solve your problem, if problem persist post comments for further help, if my answer was helpful please rate it, and Thanks for visiting Fixya.com. Best of Luck.
How do I remove the "write Protect " from my Olympus camera? I must have pushed some buttons incorrectly and suddenly it shows that "write Protect " sign. I already tried removing...
Find the flash memory card that plugs into your camera and stores the pictures. It's usually behind a door or flap on the side or bottom. Remove the card, usually accomplished by pushing it in and then it should spring outward slightly -- at least enough for you to pull it out the rest of the way. Check the card for a tiny sliding tab on the side and move it to the opposite end of its travel. See this wikipedia article for pictures and more info about write-protection.
12helpful
4answers
Please re-operate after pushing reset button
Just push the "reset" button and try again. The reset button is next to the EJECT button. You will need something small to push it in.
6helpful
3answers
NEED HELP
G'day,
I also have the same problem and after almost buying a replacement I thought I would try one time to get it to go.
What I did was start the cam without a tape in it, let it bring up the little red icon indicating no tape inserted, (it hadn't started flashing "PLEASE RE-OPERATE AFTER PUSHING RESET BUTTON" at this stage) then I inserted my tape. Hey presto, it works although for how long I don't know. I'll immediately start burn my tapes to disc while the going is good.
Hope this helps someone
Panasonic NV-GS50 - Display indicates "To Service"
This means you need to get it serviced, because it has detected a fault or error.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
