Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Error code FF
What does error code FF refer to? What part do I need to replace?
  • iliano Sep 25, 2008
    when ever i try to install SQL server 2005 sp2 i get this code error FF
  • jiddam Nov 21, 2008
    i have the same problem and i'm looking for a way to solve it
I had the same problem. I can tell you that simply unplugging the fridge and letting it defrost
isn't going to work. You need to get take it apart.
I had the Er FF code about 2 months ago and let the freezer defrost for a couple hours and it
started working again. Then two days ago I got the error again. This time I decided to get inside
there.
First and foremost, UNPLUG the fridge and TURN OFF the water!
Next empty everything out of the freezer and start taking it apart. You have to get everything out
of it to get that back panel off. This includes the ice maker and the rails that the drawers slide
on.
Now that the freezer is completely empty there are two screws that hole the back panel on. In my
freezer one is a white screw high in the center and one was a gold screw in the little panel that
the ice maker hooked up to.
Next grab the back panel by the little fins on the top of it in the middle. Give it a good firm
pull, but take care not to yank it too far... it's still connected by wires back there. When I
pulled my panel out I found a HUGE chunk of ice on the top of the panel just to the right of the fan
that feeds cold are to the fridge. Get that thing off of there taking care not to damage the foam
insulation and watch those shiny metal fins that are behind the panel.
While you're putting it back together try to dry everything off as much as possible (I tried see the
bright side of the whole evolution and realized I could really clean my freezer).
Once it's all put back together plug that baby in, turn on the water, and enjoy the next four hours
as it gets back to being cold.
I'd say you need moderate tinkering skill to do this. If you only own one screwdriver and you never
use it you should probably call someone.
Hope this helps!
Posted on Apr 21, 2009
    Problem Solver:
  • 12 Answers
ER FF = malfunctioning evaporater fan
Posted on Oct 05, 2008
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
What does ff error mean
For LG A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
Jan 06, 2018 | Refrigerators
Error code for FF for KingAir air conditioner?
Error code FF means the outdoor DC motor fault.
first check the resistance value of the DC motor port, change the DC motor if short circuit.
Nov 08, 2016 | Refrigerators
Stabilitrak error comes on then P0177
This refers to the ethanol content of the fuel used , 10 % is normal so you may have used higher ethanol content or one of the following has occoured. Open or short in FF sensor VPWR circuit - Open in battery ground to FF sensor circuit - Open in FF sensor signal circuit - Short to ground in FF sensor signal circuit - Fuel contamination - Short to VPWR in FF sensor batte.
Jun 15, 2014 | 2008 Buick Enclave
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
I have a Kenmore Refr. Model # 795.77563600 has a Error FF
The FF error code indicates that the freezer fan motor is defective.
You need a new main control board and evaporator fan motor.
The fridge is made by LG, but rebranded as Kenmore by Sears. First 3 digits is the tell. You can call Sears for parts.
LG refrigerator repair in orange county, ca
Feb 05, 2010 | Refrigerators
Error Code Er FF
Replace the defrost heater and defrost thermostat in the freezer.
Mar 23, 2009 | Kenmore Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
1,148 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
