Question about Gateway MT3705 Notebook
It won't turn on!
So I came home from work one day, and my Averatec 3200 laptop won't power on. When I hit the power button, nothing happens. The small battery shaped light flashes like the battery is charging, but nothing powers on at all. power won't turn on, red flasing light appears
  • babybunyan Jul 09, 2008
    Gateway MX6124 laptop same issue. I unplugged it and moved it onto my desk so I could work on some scrap booking with a friend. 12 hours later I move it back to it's normal home, plug it in and....nothing!!! Nobody was near it, no spillage nothing. I removed the battery, opened the back and tried removing and reseating the memory and the hard drive. I replaced the battery and still.....nothing. Even if the battery was dead, I still had it plugged in with the adapter! HELP!!!
    Problem Solver:
  • 18 Answers
Could be a power board problem. Anyone home at that time alone, possible internal damage due to spillage???? Pull harddrive, reseat memory and pull battery and try again.
Posted on Jul 05, 2008
My problems is..thi is my loptop averatec 3200 is autoamatic off end shotdown..why?
Try this. Power down the laptop, then remove the battery. Press the power button for 20 seconds. Then replace the battery and power the laptop back on. Please let me know if this helps.
Apr 02, 2012 | Averatec 3200 Notebook
I have an Averatec 3200 xp home edition. It was a gift. All that came with it was the power cord. How do i reset factory settings?
If laptops do not come with an installation disc, sometimes there is a setting in the BIOS which will allow reseting to factory settings. When the computer is first turned on, it will usually provide a specific key to access the BIOS or setup screen.
Mar 06, 2011 | Averatec 3200 Notebook
Dropped Averatec 3200 laptop and it fell on the cord and bent the power source connection. Can I fix this or do I need to send for repair?
I've had this happen to me a few times. If the pin inside the laptop is bent, then there is no question that you'll need a warranty or shop repair on the laptop to fix or replace the power port.
If the power input coming from the power supply is bent, then you can try fixing it by pushing the plug back into place with a pair of pliers. If this doesn't work, then you'll need a replacement power supply or repair.
Apr 03, 2010 | Averatec 3200 Notebook
Averatec 2200 laptop not turning on
may have damaged the motherboard on impact without breaking anything off. best bet would be to take the laptop apart and visually check for that kind of damage. should be taken to a repair shop, not done at home
Nov 14, 2009 | Averatec 3200 Notebook
WLAN switch button does not work
Locate your wireless card compartment on your computer. It is probably on the back of it. Your computer manual should tell you where it is. Open the compartment and locate your wlan card. Remove it from your laptop for about 30 seconds, and then reinsert it and make sure that the proper connections to it are firm and secure. Close up the compartment. Turn on your laptop. Your laptop should search and recognize it. If it doesn't, then your wireless card probably quit working on you. If your computer is still under warranty, and if it doesn't recognize it after you have tried this, then you can contact your computer manufacturer and explain to them what happened. They should replace your wireless card at no charge. If you bought the wireless card from some other store, then take it to them and explain to them, and ask for a replacement wireless card.
Sep 04, 2008 | Averatec 3200 Notebook
Averatec 3200 Recovery Failed
this happened to me as well, had to get a normal windows xp cd and then install the default drivers (which i had to search for hours for). good luck!
Aug 14, 2008 | Averatec 3200 Series Notebook
Averatec 2300 laptop will not power on.
We need to determine if the problem is your graphics chip or if the laptop really isn't booting. Do you get any kind of hard-drive activity light when you boot it up?
May 13, 2008 | Averatec 3200 Notebook
Suddenly my Averatec won't start
It could be your Power Supply or your CMOS Battery is dead. For Power Supply, you can test by try to connect your Power Cord without battery to see for any PowerPush. If it is still not on then you can check your CMOS Battery for any failure by test the good one from other similar laptop since you had two. I hope this help.
Apr 22, 2007 | Averatec 3200 Notebook
It won't turn on!
Flashing green battery means it is in suspend mode. Pushing the power button should bring it out of suspension, however, one of the reasons I deactivate both suspend and hibernate mode is because the seldom work right. I would disconnect your A/C power cord and remove your battery from the laptop. After about 30 seconds plug them back in and your commuter should start again. Let us know how things go.
Dec 31, 2006 | Averatec 3200 Notebook
Gateway MT3705 Notebook Logo
272 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
