Samsung TXC2516 TV problems
The picture went out and there was suddenly a high pitched screaming noise coming from the tv. There was no warning... no period of time with a flickering picture or problems with the sound... it just said "see ya later, bye!" I'm holding out with the positive assumption that this is a problem I can take care of rather than take it to a shop or the samsung burial ground. I am mechanically inclined, I just need some guidance.
Thank you so much!
Kathline Stewart
kathlinestewart@gmail.com
  • vaibhavagg Jul 05, 2008
    i tried my best by closing and opening twice but nothing is happend
  • Anonymous Aug 10, 2008
    yes same problem
SOURCE: it's a Samsung SlimFit HDTV TX-T2782
I was told that it might be a flyback transformer issue. Hope that helps, I'm still looking into getting mine fixed.
Posted on Jan 05, 2008
rey jr
  • 149 Answers
SOURCE: Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Posted on Jan 01, 2008
SOURCE: high pitch sound comming from tv!
The horizontal transistor and the flyback are damaged
Posted on Apr 24, 2008
  • 108 Answers
SOURCE: Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Posted on Jan 06, 2009
  • 159 Answers
SOURCE: when my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
Posted on May 02, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Why does my Samsung LED TV have sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 30, 2014 | Samsung Televison & Video
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Sometimes screams a high pitched noise when turned on
the high pitch noise is from the HV. arcing acrss each other.
( the screen comes up at a pop).
I suggest get a better one. ( sorry! no domastic brand).
Oct 27, 2008 | RCA HD52W56 52" Rear Projection HDTV
No picture and no sound
you need a coler weal if it macks noise.
Oct 01, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
High pitch sound and fuzzy
The high pitched sound, probably not, unless you open this TV set and find out what is making the noise and replace the part. Most likely a coil or transformer is vibrating so fast that the frequency is very high. On the focus, possibly can be adjusted. Now when you take off the back of this TV set, i must warn you, follow my instructions to the letter as there is enough High Voltage in this set to make a grown man cry! After you take out all of the screws off the rear cover,carefully lift up the cover straight up. Oh by the way the TV should be face down. Opps! Not stand back up the TV set and there will be a Grey or black block like looking thing with a large red wire going to the top of the picture tube. on this block you will find two controls, one will say screen, and the other will say focus. DO NOT ADJUST ANYTHING ELSE WHEN YOU ARE IN THIS TV SET!!! No slowly rock the focus control back and forth till you get the sharpest picture. Put back on the back cover and enjoy!!! Good Luck
Jun 13, 2007 | Samsung TXJ2879 28" TV
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
