Question about Dell Dimension 8200 PC Desktop
Dimension 8200 problem.
if someone can please help me i would appreciate it. i have a dimension 8200 and it doesnt turn on. it only blinks yellow, and also makes a slight humming noise. please let me know with any ideas.
Thank you,
Leo
  • 1 more comment
  • grkleo Jul 05, 2008
    how should i do that? should i check by replacing it?
  • Skipit91 Jul 24, 2008
    My Demension 8200 wont turn on at all.
    No lite, no humm; nuthing
  • thcustom Aug 09, 2008
    my 8200 boots up after resting for ten min. Stays on for 3 min. then beeps and goes blank. Upon shutting off and restart it beeps 5 times space 3 times. Is this a bad processor fan?
    Genius:
  • 2,785 Answers
Plz check your power supply
Posted on Jul 05, 2008
Dell dimension 8200 help
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 09, 2014 | Dell Dimension 8200 PC Desktop
When I turn on the dell dimension 8200 the light on the power button does not turn green, it stays amber color blinking and the computer does not turn on, is it the power supply that is gone bad?
Check all below possibilties & see if it works.....
  1. GGGY diagnostic lights can indicate a bad motherboard, or possibly a hard drive failure.You could try opening the case, then remove and reseat all the power and data cables, cards and memory and see if the system bootsCheck for burnt/charred power connectors on the motherboard and for any capacitors with bulging tops or are leaking, the tops should be perfectly flat.
  2. Could you please check out if the you are not having a battery problem. This could be the source of all the trouble that you are having.
  3. do the fans and hard drives spin
Please rate & vote, if you like solution
Thanks
Sandeep
Mar 14, 2011 | Dell Dimension 8200 PC Desktop
I am getting ready to intall additional Rambus memory to my Dell Dimension 8200 and need walked through it... Any help?
Hello d_silverthor,
Here's a video link shoing how to install memory in a Dell Computer:
http://www.memorystock.com/memory/viewvideo.asp?systemtype=Dell+Desktop&Class=Desktop
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Dell Dimension 8200 PC Desktop
Dell 8200 Dimension shuts down on bootup. Making
The clinking sound could well be your drive heads snapping back into parking location if your power supply is going out. Since the 8200 comes with a pretty weak power supply those tend to go out shortly after you've upgraded to a better graphics card or added another drive to the system. I've replaced mine a few times and now have a 450 watt supply in it which seems to be able to handle a powered video card and the 2nd HD, 2nd dvd without running out of juice.
Another good thing for these old dimensions is the addition of a case /slot fan to help with cooling a bit more. (see included picture)
I've had dealings with a number of dimensions from this era not cooling enough and the slot fans really helped stability.5a04930.gif
Let me know if any of this helps your situation.
Jan 24, 2010 | Dell Dimension 8200 PC Desktop
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
Need picture of dell dimension 8200 back panel
Here is a link to Dimension 8200 Front view and Back view: http://support.dell.com/support/edocs/systems/dim8200/tour.htm#1101572
The speaker jack is Green.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Dimension 8200 AUD System Board...
Dell Dimension 8200 won't power up
If the power button does not light up at all, I would guess the power supply has a problem.
Thank You.
Nov 12, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 Internal Hard Drive Enclosures
Dear Sir:
You will not get this bracket in any store however you can contact the dell support and if your system is in warranty they will send you free of cost.
Let me know if you need any further assistance and if you have a moment to accept and rate the solution I would greatly appreciate it.
Thanks,
Mohammed.
Aug 13, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 Upgrade Heat Sink Problem
you can contact online for techsupport at dell at www.support.dell.com this a live tech support session totally free they have helped me out numerous times keep me posted on how this goes ok best regards mike
Aug 12, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
101 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
