Question about ASUS P4C800-E Deluxe Motherboard
On board ethernet driver conflict with windows XP
My onboard ethernet of ASUS P4C800E Deluxe mother board must be kept disabled and even I dont install driver as it make windows XP unstable. Most of the time not even boot.
  • rborikar Jul 06, 2008
    Thank you dileep for your solution, its works! I am already on some USB Lan device. Asus is big brand and it can't just despair us in this way.After all I have spent whopping 12800Rs. only for this motherboard, that too it didn't come with onboard video. Gradually more and more device will be obsolete. Asus must support it.
    Any way thank you for the help!
  • 983 Answers
Go to the bios settings & there you can disable the onboard LAN ....
so by this you will be able to boot from your hard drive ....
you can go to the bios settings by pressing F2 (or delete key in some PC s ) at the time of the booting (before the OS loads)...
there in bios settings just search for the LAN device & disable it ...
that s all your problem will be solved ....
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Posted on Jul 05, 2008
I have ASUS M2N--68 mother board. its sound driver is not getting indstalled in Win Xp SP3. Urgent help required..
hi shreyash, do you having on board audio card mean go to bios and check weather you have disable , if it was disable mean enable it.
If you using internal or external sound card mean, go to bios Disable your onboard audio card , so only your internal or external sound card will work.
And i will give original Asus mn2 motherboard driver , install it and check it once. copy and paste the link i have given below
http://www.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
or click here
After page get loaded scroll down, click download in tab and select your OS and download your Drivers.
Good luck
Jan 11, 2011 | ASUS M2N-MX Motherboard
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
I have lost my Mother board cd to i have formated my system and i do not have lan card drivers to get internet connection and i have Asus P5GD2-TMX/GB/SI mother board and i am using Windows Xp
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Click on this link: -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Jul 05, 2010 | ASUS P5GD2 Deluxe Motherboard
LAN driver Freezes Computer
disable the motherboards built-in ethernet adapter in BIOS and get an add-on ethernet card. it sounds like your ethernet card is damaged and its affecting the rest of the computer.
May 22, 2010 | ASUS P5B-E Motherboard
Gigabyte GA-6VTXE Motherboard cant detect any USB pluged It used to detect JUST SanDisks memory, now... not even that. All windows updates installed. In manufacturer site theres just a 4in1 driver set that...
The problem is probably not software, but hardware. The BIOS probably has disabled the USB controller, or the USB controller has probably gone out, the way to tell is when you restart the computer, when the screen first comes up, press the DEL key to access the CMOS setup utility. Check around for something that says "Onboard USB Controller" or "Onboard USB Support" and if it is disabled, enable it. otherwise the Motherboard has lost the controller and you either replace the board, or get a USB controller PCI addon card. Hope that helps.
Jun 16, 2009 | Intel Motherboard
Asus P5k ethernet slot on motherboard just stopp ed working
Try tis...
1) Re-installing windows will not fix the problem. Try re-installing the
Ethernet driver (LAN). This driver should be on ASUS install cd.
2) Sometimes ethernet will just stop working. Then you should just
purchase a new ethernet card. They are rather cheap. Check out
Newegg website. You may have to disable onboard Lan in Bios.
Apr 25, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
The onboard ethernet card just stopped working. There is no fix I can find. I reinstalled windows and the drivers. once you instal the driver it only will start in safe mode.
Reboot your PC and hit F10 or F2 or any key it shows on your screen and go into BIOS setup and there should have one entry you can disable the onboard ethernet card.
How to disable onboard graphic card on asus psrd1-vm mother board
There should be a menu item in your BIOS to Enable/Disable On-board video.
Not sure what key on your computer selects the BIOS Setup Utility. Watch when it begins booting. It will show it for a few seconds. Maybe F2?
Jan 15, 2009 | Microsoft Windows XP Professional With...
I have no audio
did you do the drivers? does the sound blaster have the drivers?if the onboard failed the add on should work, if it's not broken. make sure you have the right driver. you can download them on creative labs website, or asus website for that board, but disable the onboard if you use the add in sound blaster. this should work, if you had sound before, also make sure no conflicts with sound devices. hope thi helps happy new year..
Jan 01, 2009 | ASUS K8V-SE Deluxe Motherboard
No Sound
it may look fine, but i think there is some trouble with the installation of motherboard on the new case take a review on it.
it happened to me before.I just reinstall it to the new nase and chechk for any lose connection or any busted chips. in that case try some new motherboard
Apr 07, 2008 | ASUS P4C800 Deluxe Motherboard
ASUS P4C800-E Deluxe Motherboard Logo
1,088 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
