Question about Samsung HL-P5063W 50" Rear Projection HDTV
Only black and white
I have a 50" samsung tv that i purchased about three years ago. All of a sudden i have no color on my tv just black and white. Went through men and dont know what to do.
The same thing happened to my HLP5063W. Researching the internet forums I concluded the problem was with the color wheel, which I replaced. As it turns out the old one was completely smashed. Go to www.jangro.com for replacement instructions.
Posted on Aug 22, 2008
I bought this tv, more or less 4 years ago, and I'm live in brazil. So, when I got here the Tv was black and white, no color! What's wrong? Can we help me?
Depending on where the set was purchased (USA) it may be NTSC format and Brazil is likely to be different format like PAL or even Seacam---they do make converter boxes that will convert signal from one format to another.
May 01, 2012 | Dell W2306C 23 in. HD-Ready LCD Television
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
I have a Samsung HLR5067WAX/XAA 56 inch, rear projection. Replaced lamp on it two years ago, was working fine. This morning a sudden thunderstorm blew in. When the power came back on, the cable picture...
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Here's the instructions to replace it http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php and your part # is BP96-01103A Have a bless one!
Apr 26, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Failed Samsung 40" TV
sorry to gave u a bad news bad the color card is the all panel , tell me the model # and i would check how musch is the parts
Mar 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung dlp model hlp5067wx
the color wheel has to be replaced. (Technican Job) this device is inside the light engine,
Jan 06, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hlp 4663w
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Dec 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Dec 02, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
121 people viewed this question
Henry  Thomas
Henry Thomas
