Question about Compaq Armada M700 Notebook
Power issue with my Armada M700
My M700 has started acting up. It flips between battery and AC when it's plugged in. Once or twice, it's just shut off. I tried a new AC cord, thinking the old one was shorting out. But the problem persists. I'm thinking there's a problem with something loose in the connection where the AC cord plugs in. How do I check that on my own? I don't want to spend a fortune on this old laptop to have a tech look at it.
Thanks.
  • linders Jul 08, 2008
    I think you're probably right about the problem. I'm going to see if it's something I can fix myself. What the heck, I can't break it. And I already bought a new Toshiba Satellite and transferred all my documents. If I can fix it, my sister can use it. It does tend to get hot, and I always run it with a cooling pad. But it is quite old. I also have this white crystal-like dust that comes out of the keyboard if I close the thing up and turn it over. Something in there is just crumbling from age, I fear.
  • Anonymous Feb 28, 2009
    I have that problem to, but i know how to fix it.... You need to take off your battery and put it back to the lap top! thats it, but remember, take all contacts away from the laptop couse that wont work whit contacts.
    Problem Solver:
  • 18 Answers
There is a DC jack on the inside of the motherboard, It needs a solder touch-up. Chances are good the board has been getting too hot and it cause the solder to tarnish to the point that it is not making a good bond between the board and the jack. A common problem that I fix all to often. But on the M700 I would say that a fix like that would be unrealistic as I have the best prices in town and at $150 it would make the system not worth fixing. Of course as the owner of a computer store I would take it on trade for an upgraded system but not all stores do that. Good luck.
Posted on Jul 05, 2008
Flashing power lights green and amber will not power up
Try removeing the battery form the laptop and using just AC porwer. if it still fails you may need to replace the motherboard. :(
Sep 14, 2009 | Compaq Armada M700 Notebook
Compaq armada m700 randomly shuts off, charging connection issue?
Since you have already tried using a different cable, it sounds like a loose connection, or a failing power supply. In either case, I recommend you take it to a qualified tech to check it out, before something else more expensive gets shorted out by the faulty electrical connection. It could be a simple part swap would get you back in business with a reliable laptop instead of a liability for your precious data.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Power
are you sure your get ac power, im thinking you ac plug in the computer is loose.
Dec 17, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700
Always start with the simplest solution first so start by cleaning all the contacts, AC adapter laptop plug, laptop socket, laptop battery contacts and battery contacts. How have you confirmed power output from the AC adapter? have you used a voltmeter to ensure you are getting power at the laptop end? Have you used a voltmeter to test the battery? Assuming you have tried all this don't forget that almost any component can interrupt power on some laptops, however you're 2 main culprits with this kind of problem are usually power controller (voltage regulator) and in some cases, on a laptop of this vintage, the charge controller built in to the battery. Try it with a different battery if you have one.
Aug 10, 2007 | Compaq Armada M700 Notebook
Power Issues
Seems your laptop has been sufferd a lot by the power. i just suggested you to have your mother board check.I think there should be something wrong with your mother board. By the way, did you try powering on it without the battery? If not, you should have a try on that.
Aug 03, 2007 | Compaq Armada M700 Notebook
Power failure
Hi Asadi Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps. Regards Harry
Jun 14, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
