Question about Denon Audio Players & Recorders
I have a denon avr-3600 and having major problems. I have a 5 speaker theatre system. My RHF together with my sub woofer do not work. I have gone through the troubleshooting section all to no avail. The other problem that is annoying is when i turn on the system there is a scrambled sound with what appears to be a radio station coming through faintly. I do have an external FM aerial alongside my TV aerial. The station coming through appears to be an FM station. The interference disappears after a while however small interuptions continue to occur. The interference occurs no matter if i have tv,dvd,foxtel or vcr operating. Your help would be appreciated. regards Bruce Mc Dowell
  • 43 Answers
Hi dude,
           if you have devices like radio, modems near ur receivers the interference noise which u are tellin is common...better place them away from ur receivers... however for that RHF and sub woofer problems, u need cal any near by technician or use our repair service to find receiver repairman to sort out the problem...qualified technician can alone solve dis problem...
good luck
Posted on Jul 05, 2008
  • Senthilappan PC
    Senthilappan PC Jul 07, 2008
    you are always welcome bruce,,,
    good luck
    Sergeant:
    Champion:
  • 417 Answers
Maby this Site Could Be More Help
http://www.audio-ideas.com/reviews/avr-3600.html
    Genius:
  • 1,847 Answers
If is is a crackling sound coming from the speakers make sure all the cables r connected tightly.
  • Legin Varghese
    Legin Varghese Jul 05, 2008
    Open the amp unit and chk for the output port connection and chk the voltage on the main transformer.
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
Denon AVR-487 SYS-57HT SPEAKER SYSTEM
check that wire and fuse again and try to reset and try
Dec 11, 2007 | Denon AVR-4800 Receiver
I recently purchased a new Denon AVR-391 receiver and am having a problem hooking up my subwoofer. It seems that the Denon has a pre-out RCA looking output and my subwoofer uses conventional speaker wire. ...
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
IN A SUB-WOOFER, IT CAN CANCEL OUT THE LOW NOTES.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
Mark
"Phase Cancellation"
Jan 05, 2011 | Audio Players & Recorders
Programming a Denon AVR-1907 to activate the sub-woofer
In the setup menu on your denon receiver make sure the subwoofer setting is set to ON or YES.
Feb 28, 2010 | Denon AVR-1907 Receiver
No signal coming from sub woofer out
set the front speaker to small or if still set in large,set the subwoofer setting to lfe+main.
Feb 18, 2010 | Denon AVR-1708 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Is it possible to to have a home theatre with Denon AVR 3600
one option that may yield results, since the bose connection to equalizer is presently not possible is to set the speaker out put on the denon for 'small' on all but the front speakers.
and then set the delay for all speakers based on the distance to the amp.
this should result in better audio that that with the bose eq.
will work on the issue of using the eq. with the denon if you like. but, you will likely not improve on the sound with the denon set up correctly.
good luck
mark
Dec 17, 2007 | Bose 901 VI Main / Stereo Speaker
142 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
