Question about Yamaha Emx88s Powered PA Mixer System
Yamaha emx88s powered pa mixer
......when you turn it on and talk into the microphone ,it cuts out......comes back ...then cuts out again...like theres some sort of govener ....but it's not turned up loud enough or on long enough to get hot.....any solutions?......or where to take it to fix it?
Your pushing it too much i have this p.a. and i had to get a power amp to assist other than that your mics will snap at if you sing to close to them. i run my bass thru my guitar thru 6 mics no matter what the documentation says about ohms if your not running a DJ system thru this thing only. and you want performance for live gigs with monitors and all like i do you need a POWER AMP to pick up your monitors or your mains i suggest 1200watts and up
Posted on Jul 05, 2009
Make sure your speakers are not the "shielded" type ( aka guitar microphone cable ). Alot of people think there is no difference between a guitar cable and a speaker cable. The speaker cables should be at least 14 gauge with good soldered connections and NOT SHIELDED!
Posted on Nov 21, 2008
I have a yamaha emx66me and i have had the same problem several times. it always turns out to be a bad cable between the amp and the speaker. hope this helps you.
Posted on Oct 01, 2008
Can i use powerd spekers with yamaha emx 88s
Yes. You can use powered speakers with this board
Feb 11, 2013 | Yamaha Emx88s Powered PA Mixer System
The power fuse is always blown as i keeps on changing it for the fourth time
You have a grounding issue or a short along the line. No easy way other than pulling it apart and putting a meter to it to find it.
Nov 12, 2012 | Yamaha Emx88s Powered PA Mixer System
How do i connect lights to a yamaha emx 512
There is no way to hook up any form of lights to the Yamaha EMX512S. If you want to use DMX lights, you would need to buy a DMX controller. There are both analog and software controllers. Controller prices can range from $50 to over $500.
Aug 24, 2011 | Yamaha Emx88s Powered PA Mixer System
Can i run my bose speakers from a powered mixer
You have not mentioned which model of Bose. But anyway simple rule of thumb is make sure your amplifier output power does not exceed the speakers rated power. Speaker power rating can be higher than the amplifier . That way you won't damage the speakers.
Just remember you cannot use a domestic speaker system for a commercial purpose because they are not designed to throw sound over a great distance and cannot generate very high sound pressure levels like professional speakers do. You may not achieve any satisfaction and in return may damage the speakers by turning up the volume very high. Its like trying to race with a domestic car in a formula 1 race !!!!!.Its a loosing battle all the way.
Mar 18, 2011 | Yamaha Emx88s Powered PA Mixer System
Can I plug just one subwoofer into my Yamaha EMX88S? What kind of sub do I need to get for it? Do I need to have 2 subs plugged in for it to sound right? Do I daisy chain the subs with the A15 speakers I...
it is not reccomended to daisy chain passive subs with main speakers, because there is no crossover unit involved. you want a sub to have a crossover frequency around 100hz, so that only frequencies lower than this go through the subs, and not in the main speakers.
you could get away with 1 sub plugged into the mono output on the front, subs dont have to be stereo. you would need a self popwered sub, or an additional amplifier+crossover for passive subs. your best bet would to be to get a powered sub and hook it up to the front panel mono out. powered subs usually already have the crossover built--in.
Nov 25, 2010 | Yamaha Emx88s Powered PA Mixer System
Mixer makes crackling noise while still on stand-by also volume increases involuntarily 35%
We here at proline music are Yahama dealers. It sounds like you could have a few different problems. Your head should go in for service. You can call us at 215-736-8055 if you have any more questions
Jan 15, 2010 | Yamaha Emx88s Powered PA Mixer System
I want to play my tascam guitar trainer through my yamaha pa. will there be any impedance problems . Want to use this as background music, howecer have little knowledge about pa systems. thanks
You'll be just fine. The Yamaha PA inputs are able to take high or low impedance inputs via the Line-In (1/4") input.
I would not recommend plugging your trainer into the mic level (XLR) input. The preamp will be fine, but you'll have to turn the gain so low that you'll be in the nonlinear part of the gain circuit, and the sound quality will suffer.
If that helps, hit the "thumbs-up" for me. If you have other questions, or if I can explain further, just post-back and I'll see what I can do.
Dec 23, 2009 | Yamaha Emx88s Powered PA Mixer System
Emx88s powered mixer
Try shutting the limiter switch off
Mar 24, 2008 | Yamaha Emx88s Powered PA Mixer System
Speaker connections
Not usually. They are generally parallelled inside. But if it's the jack itself and not the amp channel thats broken, you should be able to use it successfully.
Sep 13, 2007 | Yamaha Emx88s Powered PA Mixer System
Yamaha Emx88s Powered PA Mixer System Logo
618 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
