Question about Smeg Dishwashers
Broken Knob to turn on dishwasher ( Need Replacement knob)
Its an old one "smeg allegra nzl 750"
  • 126 Answers
SOURCE: Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Posted on Dec 13, 2007
  • 49 Answers
SOURCE: MIELE DISHWASHER NEEDS A NEW KNOB
give me a couple of days and ill get back to you on that one.
do you need a part number for the knob?
Posted on Feb 19, 2008
Krazytech
  • 725 Answers
SOURCE: Asko D1706
it is your overflow .. there is water under in the dishwasher tray or the float is stuck in the up position.
you will have to remove the toe panel and get the water out from the tray or free the float ( sometimes soap gets under and sticks the float in the up position... let me know if there is water or stuck switch . hope it helps
Posted on Sep 14, 2008
whytfang
  • 170 Answers
SOURCE: Locked timer knob in GE Nautilus dishwasher
I ran into this problem earlierr today ....Check the float valve...it is a round looking device in the front (usually) of the DW...if this gets stuck it will (or may) get stuck in drain or in assist dry mode...push it up and down you should here a clicking noise. Take it out and see that there is no debris in it ...if so clean it ..and replace...then try the Dw.
I hopr this helped....good luck....thanks for rating my effort...The Fang.
Posted on Mar 28, 2009
  • 3 Answers
SOURCE: The Rinse Aid Dispenser Knob has melted on my
Try this link and choose your model
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GU2400XTP
Posted on Dec 30, 2009
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
Dishwasher
I need to know who made the dishwasher.  Was it GE, Hair, Kenmore....? Pllease do not vote yet, just post a comment.
Oct 25, 2007 | Dishwashers
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
I have a new (about 7 months old) SMEG SAP112-8 60cm Linear Pyrolytic Oven. The knob to turn the oven on does not seem to work. You usually push it in (and meet some resistance) to turn the oven on, then...
We have experienced the same problem. We have a service tech coming to fix it. The knob has come off. It seems that the internal spring has dislodged itself. This will be claimed under warranty. Ours is 5 months old. Our other Linear combo oven and coffee machine seem to be more solid/sturdy.
Dec 24, 2010 | Smeg Linear Pyrolitic Single Oven Electric
Smeg ST660 not starting
Switch the power off. Remove the 'built-in cupboard' panel from the front of the dishwasher and you should see the end of the timer spindle. With the power off you can turn this clockwise using another appliance knob or carefully with pliers. I think one 'start' position is with the flat section below the centre and horizontal. If the two lights are not on then try the 'start' button second from left to advance the timer.
Jan 13, 2010 | Smeg Dishwashers
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Need Dial
go to http://au.mouser.com/Electromechanical/Knobs-Dials/_/N-5g22/
There should be something the same or very close to what you want.
Apr 15, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
95 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
