Question about Motorola Mobility L6 Cellular Phone
Motorola w315 all my phone has in the main menu is message at top, message at botton and brew on the left of the ok button. how did this happen and can i get to the phone book and other main menu options
NO LIGHT
Posted on Jul 12, 2008
I need to master reset may Motorola Blur
To Hard Reset the Motorola BLUR MB300 quite differs from other Motorola ANDROID phones.
Do back up all your data stored on your device before doing this procedure, this process will delete all the data on the phone but does not delete the data stored on the microSD memory card.
To hard reset Motorola BLUR MB300
1. Power off phone.
2. Hold camera button and power on phone at the same time.
3. Release the camera button when prompted to.
4. You will see a message screen telling you to press the up or down volume button
5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed')
6. When triangle and phone screen appears
7. Press on the screen just above the back key
8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back]
2. apply ssdcrad:update.zip [Alt+S]
3. wipedata/factory reset [Alt+W]
You can simply tap an item to select it.
At the bottom of the screen you can select OK to apply your choice from the menu.
There is also an opportunity to select Hide on the bottom left, I don't know what that does (I tried it and nothing happened).
Selecting Wipe data/factory reset and tapping Ok and the screen changes to a box and a phone (Get it - out of the box) and you see what is happening on the phone.
pick 2
-- Wiping data...
Formatting DATA:...
Formatting CACHE:...
Data Wipe Complete.
Press Menu+Back to reboot
pressing Menu+Back did nothing for me so I tapped 'reboot system now' on the menu and Ok.
The phone restart then will restore back to its factory default state.
Mar 20, 2011 | Motorola Cell Phones
Sound?
Make sure you have a ringtone assigned for your texts.
Settings<sound settings< alerts < text message< choose the sound you want to hear. hope it helps :)
Mar 19, 2009 | Motorola Mobility W315 Cellular Phone
My motorola W315 has been restarting itself lately at random times. Now, all night tonight, whenever I try to send a text message, once I press send it shuts itself down and restarts. On top of that, I'm...
sir
its the same problem which i had with my phone.
there is no problem with your phones software but with hardware. Your phones HEAP(RAM) has became very weak to take load of your phone. I will advice you to go to a nearby motorola shop. If its under warranty it will be repaired free of cost.
thankyou for using fixya
dont forget to rate the solution
Mar 11, 2009 | Motorola Mobility W315 Cellular Phone
Text & messaging - Motorola W315
same thing happened to mine. ya cant fix it sorry to say. getting a new phone might be best.
Feb 04, 2009 | Motorola Mobility W315 Cellular Phone
Razorv3 can't turn off key tones please help
From the main menu, select the bell icon to the left, then select loud detail and scroll down to key volume and set it to 0.
Jan 16, 2009 | Motorola Mobility W315 Cellular Phone
Motorola cell phone sound problems W315
On the left side of the phone are two button: A rocker button and a push button. With the flip CLOSED, push the rocker button down. you will see Style:Silent. Push the other button until Style:Loud comes up. Push the rocker button down again to exit the function. Open the Flip and use the rocker button to set the Ringer volume. You can set the ringer volume however you want for each style. My phone swiches by itself constantly when I put it in my jeans pocket, very annoying.
Nov 01, 2008 | Motorola Mobility W315 Cellular Phone
Problem ringing after viewing pics or access apps
Have you installed any other applications on you phone which might be using up the memory when u get a incoming call. Check the memory status when this happens in the phone main menu. Top left main screen>botton left menu>memory status. If this is the issue that get a memory card transfer all your songs to the sd card, if you like listening to the music use the S9 BT headset, it has a good performance dleivers gr8 sound. Cheers
Jan 05, 2008 | Motorola Mobility ROKR E6 Smartphone
MOTOROLA W315
J'aimerais que mon Pc reconnaisse mon MOTOROLA W315
Oct 18, 2007 | Motorola Mobility W315 Cellular Phone
Motorola W315 Screen Problem
i have the exact same problem... you could find someone with the same phone and find out how to get to the master reset without looking at the screen..that might work, but you would have no numbers.
Aug 08, 2007 | Motorola Mobility W315 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
