Question about Philips GoGear SA178 MP3 Player
How can i installed
I have a problem with my gogear philips it's says Please connect player to pc, but i ready connect maybe a need the software.
    Problem Solver:
  • 44 Answers
Here are some ideas:
1. try to install the software again that came with the mp3 player.
2.get a firmware update by going to www.philips.com
Posted on Jul 05, 2008
Just purchased Philips GoGear Vibe mp3 video player 8 computer does not reconize it is connected
Your GoGear is likely in MTP connection mode, which requires proprietary drivers to connect. If you are trying to connect it as a standard mass storage device, switch the player to MSC connection mode. To do this, select "PC connection preference" in the Settings menu.
As an alternative, I recommend using the the Philips Songbird software that came with the device. This software is useful for automatically converting most media files to GoGear friendly format during synchronization. And, installing this software will also install drivers necessary for connecting the device in MTP connection mode. More importantly, when your corruption prone GoGear gets the familiar "file system error" screen, the software can be used to repair it.
If you do not have Songbird, download it for Windows or Mac here:http://www.usa.philips.com/c/mp3-media-player/22126/cat/en/#/difference/philipssongbird.
If you've found this information helpful, please indicate as such.
Feb 28, 2013 | Audio Players & Recorders
Gogear vibe will not connect to either of my computers?
Uninstall the gogear driver- the media convertor- from the PC, then install once again the driver into the PC and then convert the media to be converted and copied into the player.If the driver is not installing then you will need to download the driver;
http://www.userdrivers.com/MP3-Player/Philips-GoGear-SA3104-SA3105-SA3114-SA3115-SA3124-SA3125-MP4-Player-Media-Converter-Software-1-0/
Oct 11, 2011 | Philips GoGear ViBE Digital Media Player
How to connect the philips to the pc
First you need to download software for your player.
You can download from the link given below:
GoGear Software
Install the softwares downloaded in the above link.
Connect one end of USB cable to pc and another end to GoGear Vibe player.
Software will detect the player and follow online instructions to carry out your purpose for connecting the player to pc.
Hope this helps.
Please feel free to contact if you further queries.
Shane
Feb 01, 2011 | Philips GoGear ViBE Digital Media Player
Hello sirmy philips mp4 go gear in not acceable. If i connect with pc then also say same command....how to solve it.
Maybe you need to download a software or a COnverter so that you may use it to connect to ur pc...
Jun 10, 2010 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
Hi team,i am facing problem with philips go gear 2GB player, Problem is :when ever i switch it on,"please connect to Pc and use device manager to repair" please help me in this scenario,explain...
I'm not a team member, but
1. Select your GoGear 2GB player from this list:
http://www.search.philips.com/search/search?q=GoGear+2GB&s=all&l=global&h=all&o=
2. When not having the program Philips Device Manager installed on your computer yet: Look under Software and Drivers, select the Device/Firmware Manager for your player.
2.1 Run the execute file Device Manager for installing the Device Manager toolbox.
3. Run Philips Device Manager:
  1. Having launched Philips Device Manager at Start -> Programs -> Philips Digital Audio Player -> SA2XXX -> Philips SA2XXX Device Manager on your PC
  2. Connect your player to the PC
  3. Device Manager should acknowledges your player and automatically goes into recovery mode.
  4. Follow the instruction of the Device Manager.
  5. After the player has been repaired, remove it from your PC and re-start.
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Feb 21, 2010 | Philips Audio Players & Recorders
How do i connect to computor to download music?
You will need the Philips power supply unit, attatched is the cable which plugs into the base of the gogear also on this cable is a USB plug, this then goes into your PC. You will need Windows media player version 10, for the gogear to be recognized and transfer your music/photos/etc.
You should also have the Philips software installed on your PC.
Sep 29, 2008 | Philips GoGear HDD6330 MP3 Player
A problem with my philips gogear...
The Device Manager came with the installation CD. If you lost the installation CD, you can get the Device Manager by going to www.usasupport.philips.com and entering in your model #, and going to "software & drivers"
If Device Manager is already installed, you can find it by going to Start --> All programs --> Philips Digital Audio Player --> Philips Device Manager
Jun 22, 2008 | Philips GoGear HDD6330 MP3 Player
LOST SOFTWARE
Hey, this maybe a bit late, but you can go to www.support.Philips.com to download missing software and drivers.
Oct 31, 2007 | Philips GoGear SA178 MP3 Player
Philips GoGear SA178 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
