Question about Car Audio & Video
Pioneer deh-p6600 wiring harness schematic - Car Audio & Video
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: got a new deh-6000ub and
You need an installation harness. You can get them at most anyplace that installs car stereos. Once you have the installation harness for your car, you just match up the colros of the wires on it to the same colors of the harness for the Pioneer. Make sure that each wire is insulated from anything by using some electrical tape and make sure they all have good connections. Strip away close to about an inch on each wire and then twist them together and then tape them good. After all the wires have been connected, all you need to do is plug the Pioneer harness into the Pioneer radio and then plug the installation harness into the factory wire harnees connector in the car. If you have any wires that do not match up in color, you can normally leave then not connected to anything, but make sure they are insulalted with electrical tape. Most all the wires should say what they are for. Matching the colors is the easiest way to do this.
Let me know if you need more help. I can always give you a detailed wiring of the Pioneer. I do not have the wiring diagrams for the car though.
Posted on Jul 21, 2008
MrLard
  • 94 Answers
SOURCE: im sittin here with the
Here's the manual for the Pioneer -->LINK<--.
This is the 2 options of install wiring on a 97 Altima, I'm not sure if it's exactly the same, I suggest that you don't trust these pinout if yours differ at all.
Radio Constant 12V+ Wire: Pink
Radio Switched 12V+ Wire: Blue
Radio Ground Wire: Chassis
Radio Illumination Wire: Red/Green
Radio Dimmer Wire: Red/Yellow
Antenna Trigger Wire: Green/White
Front Speaker Size: 4′ x 6′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Brown
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Black/Yellow
Rear Speaker Size: 6 1/2′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Orange
Left Rear Speaker Wire (-): Black/Pink
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Black/White
THERE IS AN ALTERNATE WIRING COLOR CODE
THERE IS NO CONTACT PIN OR EXISTING WIRE THAT IS GROUND !!!!! (some really strange things happen to aftermarket radios if you think the Red/yellow wire on pin 9 of the 10-pin connector is ground”!!!!!
Large 10-Pin Connector:
Constant Hot (Memory or Clock) =RED wire pin8
Switched (Ignition) Hor = Blue wire pin4
Left Front Speaker + = Blue/white pin1
Left Front Speaker - = Blue/yellow pin5
Right Front Speaker + = Brown pin2
Right Front Speaker - = Brown/white pin6
The Smaller (6-pin) connector is only for the rear Speaker:
Left Rear + = Red pin5
Left Rear - = Green pin4
Right Rear + = Blue pin2
Right Rear - = Pink pin6
Regards
Philip
Posted on Jul 22, 2008
XiniK
  • 39 Answers
SOURCE: I have a pioneer head
your local pep boys will have them. if they dont, take it to any car audio installation place.
Posted on Aug 16, 2008
bkackerson
SOURCE: Pioneer DEH-P30001B Car Receiver- recently
the owner's manual is available online on the pioneer website at http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/DEHP3000IBOperationManual1023.pdf
the first 51 pages are in english
Posted on Oct 30, 2008
XSdB
  • 80 Answers
SOURCE: need a wire diagram for pioneer DEH-1100 super tuner
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Posted on Jun 12, 2009
How do you set the clock on a pioneer deh-p6600?
Go to the link below then scroll down to product details. Then click on product manual. On page 32 it will tell you how to set the clock.
http://www.amazon.com/Pioneer-DEH-P6600-player-Full-DIN-dash/dp/B00025YP6S
Apr 24, 2011 | Pioneer Audio Players & Recorders
Pioneer DEH-P6600 wiring diagram
Aug 20, 2010 | Pioneer DEH-P6600 CD Player
I have a pioneer super tuner3d it has a mute wire where does it hook up to
This is directly from the installation manual from pioneer website for model DEH-P6600
(Yellow/black
If you use a cellular telephone, connect it via the
Audio Mute lead on the cellular telephone. If not,
keep the Audio Mute lead free of any connections.)
Basically, you don't hook it up unles you have a cellular telephone in your vehicle, not a personal cell phone.
Mar 09, 2010 | Pioneer DEH-P6600 CD Player
I need to install a pioneer deh-p6600 in a 95 rodeo.
you only need 2 things and a few tools and tape or crimp clips and crimp tool, 1. installation kit for that year and make, 2. wire harness for that year and make. then all you have to do is follow the colors on the harness and radio harness, yes they are color coded.
Jan 10, 2010 | Car Audio & Video
Set clock how to deh p6600
press function to select clock
press function repeatedly until clock appears on display
press < or > arrows to select part of clock to adjust
press Up or Down arrows to change hour/minute
Here is the address link for a download for your exact owners manual:
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/ci.OPERATION+MANUAL+DEH-P6600+20040225.Protected
May 10, 2009 | Pioneer DEH-P6600 CD Player
DEH-P6600 and DEH-P6700
if you still have that deh-p6600 faceplate i'll buy it from you
Sep 25, 2008 | Pioneer DEH-P6600 CD Player
Will a DEH-P660 faceplate work on a DEH-P6600?
yes they are the same radio 1 is just premier brand pioneer
May 02, 2008 | Pioneer DEH-P6600 CD Player
No sound
The IC amplifier of the stereo are damaged thats the reason of the lack of sound,
Apr 05, 2008 | Pioneer DEH-P6600 CD Player
Pioneer deh-p6600
It is harder to find an installation kit for this car. I recommend all new wires and speakers to get the proper sound. If you have after market speakers, then you just have to find the red wire and black. This the live and ground. The speaker wires can be done through trial and error by connecting one at a time. It would work the best with a multimeter. That way you are sure of where the power and ground are. Sometimes you find installation kits for your car by going to Futureshop or Wal mart. If they dont have it, they may tell you where.
Dec 22, 2007 | Pioneer DEH-P6600 CD Player
Car Audio & Video Logo
1,283 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
