Question about Sony VAIO Digital Studio PCV-RX860 (PCVRX860KIT1) PC Desktop
Hi-speed USB host
I installed a webcam on my laptop but it seems that my computer does not have a hi speed USB host to run the said device. Please tell me what to do.
  • 661 Answers
This means that you do not have a USB 2 port or do not have the USB2 drivers installed correctly if it does,
check your chipset drivers and spec of laptop with manufacturers.
if you do not have usb2 you can get a USB 2 PCMCIA card to supply this functionallity.
it is possible this is a USB low power issue as this is a laptop, but check your drivers and spec first.
Posted on Sep 28, 2008
Recently, when I insert a USB flash drive into my laptop's USB port, I get the message: This USB device can perform faster if you connect it to a HI-SPEED USB 2.0 port.
Your laptop has USB1 port and the USB 2 message will appear if you plug an USB 2 device into this USB port.
You maybe able to upgrade the USB port to USB 2 if there is a BIOS upgrade available from the laptop manufacturer's WEB site.
If not you maybe able to get an USB 2 PCMCIA card to install into the PCMCAI slot on your laptop.
Dec 04, 2012 | Computers & Internet
Need Hi-speed usb host controller
. If you have an empty PCI bus slot on the PC motherboard, you an install a PCI card which provides you 2 or 4 USB2.0 ports which are available at around $10. There are some combo cards which provide both USB and Firewire (1394 ports).
Oct 06, 2008 | Toshiba Televison & Video
I get there is not hi speed usb host controller available on your computer when I insert a Pen drive and the transfer rate to the pen drive is pathetic. Please help me
The problem you are decribing is one that many people with older machines experiance.
The USB Host controller in your machine is USB 1/1.1 while the device is an USB 2 device (much faster)
If this is a desktop you should be able to find a PCI card that will support USB 2
If this is laptop there are PCMCIA (cardbus) cards available for this also
Jan 03, 2011 | Computers & Internet
A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Aug 09, 2010 | A4tech Viewcam PK335 Webcam
What is the version of the usb port on a compaq presario 1200
Hi again, after extensively searching I believe your Laptop has a USB version 2.0.
Most PC's manufactured before 2001 were USB 1.0 and USB 1.1.
The Spec Guides for your PC indicate 2002 was the year of manufacture.
USB 2.0 is a faster USB connection than version 1.0 or 1.1. You might have trouble connecting devices that are USB 2.0 (which all new devices are now - since 2001).
To double check, use your Device Manager on the PC to look up the USB device and see what is written.
If you are using XP then do the following:
  1. Click Start
  2. Click Settings
  3. Click Control Panel
  4. In the Control Panel double-click the Systems icon.
  5. In the System Properties window click the Hardware tab.
  6. In the Hardware tab click the Device Manager button and you will see a list of devices.
  7. Click the + button next to the word the Universal Serial Bus controllers.
If it is USB 2.0 then it should say something like USB Enhanced or USB High Speed, this means it is USB 2.0 compatible.
I hope this helps. Please rate. Regards,
Feb 12, 2010 | Compaq Presario 1200 Notebook
Logitech QuickCam1150 Notebook Deluxe camera not configured properly in xp error
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Nov 10, 2008 | Logitech Webcam
Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Sep 20, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Mercury MOTHERBOARD KOB P4M266 NDFSMX
I AM NOT HAVING MOTHER BOARD CD TO INSTALL HIS DREVERS AND HOW TO DOWNLOAD HIS DRVIERS BY INTERNET
Mar 04, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Black screen
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Jan 17, 2008 | Canon PowerShot A540 Digital Camera
Usb issues
Dear customer,
Though you get these msg's which you have mentioned, you can ignore them, and try manualy installing the driver software for the camera, somehow.
Thankyou
Jan 14, 2008 | Canon PowerShot A540 Digital Camera
Sony VAIO Digital Studio PCV-RX860 (PCVRX860KIT1) PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
