Question about Microwave Ovens
I was given a Galanz Grill/Microwave Oven WD900A for my 54th birthday 24 jan 2008 it is July 2008 and the micro wave has lost its heat power.It saddens me that a real nice microwave only had a short life.The Serial No 070900180 I assume was manufactured year 07 Month 09 September Product 0180.How can you solve this problem for me. Maureen Paku email pakum@xtra.co.nz
  • daniel-case0 Sep 15, 2008
    will not heat up galanz model wp1000ap38-2
  • Microwave Ovens Master
  • 9,098 Answers
In your owner's manual, you should be able to find contact info for Galanz so they can arrange for repair. Hopefully it has a full year's warranty.
Otherwise, I would ask the person who gave it to you what dealer or store they purchased it from, and the store should have contact information for Galanz in your country.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
Not fixed yet and i don't want to join your premium plan cause it cost money
Posted on Jul 07, 2008
Panasonic microwave grill not working
I would call customer service with the model number to see if this is a known issue. You might also call a authorized Panasonic repair center and chat with them to get some idea of what a possible repair might cost.
Dec 04, 2012 | Microwave Ovens
Baumatic microwave BTM 25.1 SS not working
Bad Magnetron DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Microwave Ovens
WHY DID MY MICROWAVE OVEN BURST INTO A FLAME AFTER 30 SECONDS ON HIGH POWER? TWICE. LMV1314B bought Jan. 2008
Actually you don't need to replace the microwave, you just need to replace the carboard piece or "wave guide" and replace the magnetron inside the microwave behind the cardboard piece. The magnetron will commonly arc out to the wave guide if the wave guide gets something that splatters on it. The repair isn't cheap because the magnetron costs about $200 and the wave guide is another $30 or so, but if you replace both these parts you should be good to go again.
The magnetron usually have 5 years warranty, however you need to speak with manufacturer itself for the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 23, 2011 | LG LMV1314 Microwave Oven
My micro wave stop heating food, every thing dislay work fine. when start it make loud sound. Sharp carousel II, model = R-3A54, Manufacture jan,1993
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 27, 2011 | Maytag MMC5000 Microwave Oven
My sisters has a Sharp microwave r-403hw was manufactured july 2003 my question is how long are you allowd to keep a microwave for and if the inside chips from the paint is still ok to cook food in it or...
As long as the microwave oven is working to heat or cook according to the program set , the micro wave can be used safely. Now if there is any chipping of the paint within the oven chamber, then you can re-coat the inside with non conducting ceramic paint.
However if there is no issue if there is no damage to the inside or to the working of the microwave as you can use the oven till it fails to heat.
Jan 25, 2011 | Sharp R-403HW Microwave Oven
Micro wave will not heat has a picture of a little micro wave on the screen
Either the power board to supply the magnatron or the magnatron is defective.
Check or have someonr check the output of power supply. If ther is a hi reading, then change magnatron
Aug 05, 2010 | General Electric Microwave Oven
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Dec 28, 2008 | DeLonghi MW 605 Convection/Microwave Oven
Instructions for Sharp R953 900wt jet convection grill microwave
i have need instruction book how i can use sharp micro wave oven r953
Dec 27, 2008 | Microwave Ovens
Microwave Ovens Logo
382 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
