Question about GE Dishwashers
GE DISHWASHER
Dishwasher fills with water and then stops
    Novelist:
  • 161 Answers
On most older Ge dishwashers this usually means a locked up motor. You should be able to hear it hum when it tries to start. The shaft between the pump and motor gets rusty, swells and locks up the motor. You can sometimes coax it to life for a little while by removing the front panel and spinning the fan in the motor by hand. Sometimes this lasts a couple of months. This problem usually shows up when it has not been used for a while. A new motor costs around $100 and is usually not worth fixing. It is very easy to install though. But you do have to completely remove the dishwasher to do so.
Posted on Jul 05, 2008
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
My GE Nautilus dishwasher takes water in and then stops and nothing happens. I tried flusing it with hot water and vinegar and no progress. Any ideas are very welcomed. Thank you.
Flushing the hose with hot water and vinegar would not help.
If the machine is filling and then stops, parts that may be responsible are the impeller pump and the control board.
If the machine is under filling, test also the floater switch.
If the water is not warm, check the heating system or the hot water supply.
If this machine has dual inlet, test that both solenoids are opening.
Dec 02, 2009 | GE Dishwashers
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water fills up dishwasher after complete maybe a day or two later
Sound like the hot water sonenoid is stuck in the open position. Locate this solenoid and tap it lightly with a small hammer while the hot water is open. If it does not stop it will beneficial to have this part replaced. I hope this will help.
Jan 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher conitues to fill even if unplugged
If the dishwasher is filling with out the power on, you have a defective inlet water valve. If it's new, have them repair it under your warranty. If not the part number is wd15x10003. Easy fix, on the left side behind the toe panel...Catriver...post back.
Aug 14, 2006 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwashers Logo
140 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
