Question about Frigidaire FRS23R4A Side by Side Refrigerator
GFI problem The fridge was not plugged into the GFI outlet directly. It was plugged into a 'normal' outlet with a GFI in its circuit. Also the fridge has now lost its cooling ability, both freezer and fridge are room temp
  • 26 Answers
MOST OF THE TIME THE TEMP IS NOT COLD ENGOUGH IS THERE IS NOT ENOUGH VOLTAGE GOING TO THE COMPRESOR.
YOU CAN CHECK BY PLUGING IN A VOLTAGE METOR IF YOUR NOT GETING 115 OR HIGHER THATS YOUR PROBLEM. AS FOR THE OUTLET YOU FRIG SHOULD BE ON A DEDICATED CERCIUT BUT IF NOT GET IT OFF THAT GFI CERCIUT.
Posted on Feb 01, 2009
What would cause intermitant pop of ground fault. only thing on the line. ground fault has been replaced
Refrigerators are not recommended to be plugged into a GFI outlet. Depending on the age of the fridge there will be spikes in the current the fridge uses at certain times causing the GFI to trip. A GFI outlet is much more sensitive to current than a non GFI outlet that is tied back to the the regular breaker in the electrical panel. Pleazer Appliance...
May 06, 2014 | Whirlpool Refrigerators
Reset button ac unit
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 26, 2013 | Frigidaire Heating & Cooling
Our Magic Comfort plus is 4 years old and it keeps blowing the gfi instantly when I plug it in. I have had this problem occassionally in the past and it resolves after one or two gfi trips. Now if tripo...
The problem believe it or not your gfi is warn out. I am actually surprised it lasted as long as it has and surprised it worked at all. Espresso machines use a huge amount of power when turning on compared to maintaining power. When espresso machines first turn on the take a huge surge of power to start heating up the elements. Normally you want to put an espresso on a circuit /outlet that is directly to your breaker that is at least a 20 amp breaker. By code kitchens and bathrooms, where an outlet is near water, has to have a gfi outlet, this is for safety for something plugged in near water so it will trip if accident happens with appliance near water. The bad news there not to good with high demand power appliances such as espresso machines. Yes , you can replace the gfi circuit, by turning off main breaker, unscrew gfi from wall, pull out, and undo wires, and copy exactly when re-wiring the new one. Then turn on main breaker again. NOTE: you can buy a gfi all most any home improvement center, lowers, home depot, ace hardware etc.... Think of a gfi kind of like a advanced in line fuse, they do wear out. BUT AGAIN, my advice is plug it in a outlet that does not have gfi and is on a main breaker of at least 20 amps if you have that opportunity to do in your kitchen area. Hope this helps you, thank you....... MIKE
Jul 26, 2011 | Saeco Magic Comfort Plus Espresso Machine
No power - seems to be totally off
check the breaker box and check to see if you have another plug outlet that's out with a gfi on it,i've found this before the electrician wired the outlet for the sub zero off of an outlet with a gfi on it,the fuse popped on the outlet and killed the power to the subby,usually if you remove the top front grill and look on the right hand side you'll see the plug for the machine,you can plug a light or anything you have handy and check to make sure it's not the fridge and it's an electrical problem,if the fridge and the freezer are both out most likely it will be an electrical problem because they are like two machines built into one,freezer and fridge are separate not like a regular fridge.if you do find that it is on a gfi circuit have a separate line run up just for the sub zero.if the problem is with the sub zero it would be wise to call in a tech that works on them,could be a bad computer board but they will do some checks and figure out what's up,they are a little complicated to work on.good luck
Jun 12, 2011 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerator has electrical short causing GCI outlet breaker to pop. Is this an easy or cost prohibitive fix?
It is possible you have a short. However, the more likely cause is the simple fact the refrigerator is plugged into the GFI outlet. Try this first, take a heavy duty three prong extension cord, NOT a lamp extension cord, plug it into a non GFI outlet, and plug the fridge into the cord. Does it trip your house circuit breaker? If so, then you do have a short. You will need to call a local refrigerator repair company to find the source of the short, and only then will you know if its an easy or cost prohibitive fix. If it does not, and it likely wont, the problem is that a GFI outlet detects a fault to ground. Due to the humidity and moisture inside a refrigerator, and normal water drainage sometimes into the metal base of the refrigerator, it is not uncommon for water to contact metal points inside and outside a refrigerator. Since all / most metal points on a refrigerator are grounded to each other, if water contacts any of them, they can and will trip a GFI outlet breaker, because it is detecting a fault to ground.
Nov 09, 2010 | GALAXY Microsystems 63702 Top Freezer...
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My frig will be working fine then it trips the GFI outlet. you reset the out and it will trip it again a few minutes later.
Why do you have your fridge plugged into a GFI outlet? It is not necessary if the outlet is hidden by the fridge. A GFI is only used where an outlet is within 6 feet of water and is out in the open. I would replace it with a new regular outlet.
Sep 14, 2009 | Refrigerators
Side by side running all day door left adjar. blew gfi reset but not running is there a reset button for the compressor
It could have popped the gfi plug , when in defrost . It can draw up to 6 amps in defrost . Use an extension cord to another outlet not gfi . If in defrost when popped , after plugged in for a little while (28-32 min) , it should cycle on . I wouldn't leave it permanently on extension cord , but replace that plug behind fridge to a normal plug (not gfi) .
Aug 27, 2009 | Whirlpool Refrigerators
Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Jul 04, 2008 | Frigidaire FRS23R4A Side by Side...
The fridge keep tripping the GFCI. I reset it and one minute later it trips again. I even tried it on a different GFCI circuit, still trip. Thank you
Refigerators should NOT be on GFI-protected circuits. Problems have occasionally been reported when plugging a refrigerator, freezer or other motor-driven appliance into GFI-protected circuits. These appliances generally have a motor that pulls significant startup current. Due to the electrical characteristics of motors, the startup current can look like someone getting electrocuted, causing the protection system to trip. The best remedy is to connect these appliances to a non-GFI outlet. Usually outlets that are expected to serve such appliances will not have GFI's installed.
Apr 19, 2008 | Refrigerators
Frigidaire FRS23R4A Side by Side Refrigerator Logo
117 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
