Question about Sony VAIO Digital Studio PCV-RX860 (PCVRX860KIT1) PC Desktop
Usb driver device
Hey wiz,
I FORMAT MY HARD DRIVE FOR MY VAIO PCV 860,I DON´'T HAVE
THE ORIGINAL CD,BUT I MANAGE TO DOWNLOAD SOME DRIVER
EXECPT FOR ONE WHICH IS FOR THE USB DRIVER DEVICE PLEASE
TELL ME WHAT TO DO .
    Genius:
  • 2,785 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}plz check the website below
www.driversdown.com www.soft32.com,
driver
zone.com,
www.driverfiles.net,www.download.com,www.driverskit.com,www.driverguide.com
Posted on Jul 05, 2008
SONY VAIO PCV-1112 CANT USE KEYBOARD OR MOUSE
Please test it using other USB keyboard and USB mouse, and see the device status in the Control Panel (Control Panel, Device Manager). Is the keyboard item missing? Is there any USB item with an exclamation mark?
Feb 18, 2014 | Sony VAIO PCG-505 PCG-671L PCG-700...
I wiped out the dvd and cd driers on my son pcv-rs310
Uninstall both of the drives from Device Manager located under My Computer and then scan your computer for new changes it should detect the drives and it will install the driver itself hopefully you are using win 7 or vista it will install the driver itself.
Jul 20, 2012 | Sony VAIO PCV-RS310 PC Desktop
Is it possible to make two hard drives into boot devices?
Yes. It is called "Dual Boot" or "Multi-boot". You can even have different operating systems on each drive or partition. For more information, just click this link.
Feb 16, 2011 | Sony VAIO Digital Studio PCV-RS410 PC...
Need 2nd hard drive for sony pcv-rz24g
You need a ATA-100 (EIDE) 3.5" hard drive. Then you need the jumper set to slave or cable select (if you have the two drives on one cable and the original drive as the master). See your manual for details on the procedure. You need to open the case, remove the cables from the original drive and lift the drive holder out of the case to insert the second drive. The manual is available here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRZ24G (see page 44 (57 as the pdf reads) and on) . Then slide the case into place and connect the power and data cables to both drives. Then go to the drive management to format the new drive and prepare it for use.
For XP, go to My Computer, then Manage. Then Select Storage and Disk Management. Then select the new disc for formating.
I hope this helps.
Jan 30, 2011 | Sony VAIO Digital Studio PCV-RZ24G PC...
A required cd dvd drive device driver is missing
i think you need a new windows cd that has no errors, your cd might have some files missing
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Sony Vaio USB ports not recognised by XP
It is common problem on most of the PC USB ports does not recognise external hardware.It is mainly due to lack power supplied by the USB Ports..You can try with Old Pentium4 maschines.IT Reads well..
Another thing dont use extension ports to plug external HDD..always use backside on board ports.\
IF it helps rate me
Jun 25, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
I just reset my sony vaio to factory settings and i have no sound what do i do??
try downloading the audio driver and install it. if you are using Sony VAIO PCV-J200 you can download your audio driver here http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVJ200&upd_id=174&os_id=7
Jun 10, 2009 | Sony VAIO PCV-J200 PC Desktop
Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Nov 05, 2008 | Sony VAIO PCV-RX500 PC Desktop
No sound on Sony Vaio rs 720G after installing new hard drive
here is the link to the drivers http://esupport.sony.com/perl/swu-list.pl?mdl=PCVRS720G&UpdateType=Updates
check em all out in your device manager (start-settings-control panel-system-hardware tab-device manager) look for things with yellow ! or ?'s next to them. You may need more drivers than you think.
Oct 21, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Sony VAIO Digital Studio PCV-RX860 (PCVRX860KIT1) PC Desktop Logo
76 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
