I tried to print a document & it didn't print & is now stuck in the printer cue. now i cant print anything.
    Genius:
  • 2,785 Answers
Just cancel the job from the que by switching the printer off, reload the drivers for the printer
Posted on Jul 05, 2008
Lexmark Optra S1250 Printer - Message "38 Memory Full". I tried to power on the printer without the printer cable attached.
You may have a document (or multiple copies of the same document ) stuck in the print queue. Turn off your printer, then pull the plug. Got to the control panel (or equivalent) on your computer and check the Lexmark print status for content and delete it, if possible. Reconnect the data cable to the printer, then reconnect power and turn it on to initialize. Cue up the print job again and go.
Feb 16, 2018 | Lexmark Office Equipment & Supplies
My dell dimension 2400 series computer has lost comms with the local dell AIO A920 printer. Connections seem to be good. It seems a print job has got stuck somewhere. HELP! AJCook
how your printer icon is looking on control panel, if dim, it means it is not detecting , if normal it means detecting then,
go to control panel open printers, then open your printer, cancel all the documents, then send a print command and check
Nov 01, 2008 | Computers & Internet
My HP printer stopped working and is stuck in the cue
Navigate to Printers under the control panel and try deleting all current print jobs. Then also make sure to click on Printer> and see that the Work Offline option is NOT checked. Good luck
May 27, 2012 | HEWLETT-PACKARD Computers & Internet
Print jobs stuck in cue
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jun 25, 2010 | HP LaserJet 8500 Color Printer
Unable to delete/cancel print job while it runs-lbp 2900
Hi.
To temporarily delete the print jobs in the cue do the following:
Disconnect printer USB.
Restart printer.
Restart computer.
Access printer cue with printer not connected (get there from control panel)
Clear printer cue.
Connect the printer back.
If the printer cue gets stuck too often, and always with different documents, try reinstalling the printer software.
Regards.
Ginko.
May 26, 2010 | Canon LASER SHOT LBP-2900 Printer
My printer isn't printing but it will scan and copy. It has items in the cue to print but they aren't working they are sitting idle.
First reset the computer and printer.
  • Unplug printer from wall
  • Restart computer
  • Plug printer back in to wall
Try to print now. This commonly occurs when files are stuck/corrupt in the print cue.
Remember
  • Only hit the print button once.
  • If it doesn't print immediately wait.
  • Wait some more
  • Open your printer que (xp Start button>Control panel>printer and faxes> double click on the specific printer.)
Now if this continues, use the above to see if the file is stuck in the cue. Try using a print test page from the printer control panel before anything else.
If the Test page works and your other print doesn't, then it is your application. Print from something else.
If even the test page won't work, then it is your drivers or your supplies are low.
Many of these printers won't work if you are out of ink. There may be a light on the printer flashing and you are out of ink.
Oct 23, 2009 | HP PSC 1410 All-In-One InkJet Printer
I have a document that is stuck in printer cue, stating...deleting. I have tried canceling it etc.
In run window type services.msc and the go to print spooler option just stop and restart the service.and switch off and switch on the printer it will clear the pending job.
Oct 20, 2009 | Dell V505 All-In-One Printer
I have a problem with t644 indicated 900.00 service rip software before this error printer indicated 960 service.after turn printer off then on error code indicated immediatly
Try this...power off printer. Then if it is a network printer go the to print server and clear all the documents from the print cue. If it is a local printer clear all documents in the local print cue then power the printer back on. Once the printer powers up the error should clear, if it doesn't clear power the unit back off and ensure that all documents have been removed from the print cue then power printer back on. This worked for me on the C782e, x854e and x940e models that I have.
Jul 04, 2009 | Lexmark T644 Laser Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
64 people viewed this question
k24674
jasbo
jasbo
