Question about Refrigerators
LG Refrigerator Water is dripping inside the refrigerator
  • djd6 Nov 05, 2008
    The defrost water is not draining out. But where is the drain entrance and line located?
  • 481 Answers
  • the drain line in the freezer may be clogged forcing water to drip into the freezer. clean out the freezer and pour some hot water in the back of the freezer to unclog the drain.
  • another cause of this would be if the door is not sealing properly then the inside of the refrigerator will build up condensation.
Posted on Jul 05, 2008
Lg refrigerator leaks water inside
Probably water reservoir is leaking. It or tubing going to it probably is cracked.
Sep 28, 2017 | LG LSC26905TT Side by Side Refrigerator
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water dripping inside top of refrigerator.
if freezer is on top what is happening is your drain hole behind freezer panel is clogged
Nov 11, 2009 | Refrigerators
Lg refrigerator icemaker leaks
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 30, 2009 | LG LSC26905TT Side by Side Refrigerator
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is dripping inside the refrigerator from one of the holes in the top in the area back from the light
The drain is plugged and in defrost the water has to go somewhere. Try to blow out the drain with air. Or you might have to remove the evaporator cover to get hot water down the drain. First try to clear the line.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Dripping water dispencer
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
Nov 12, 2007 | LG LFD22860 Stainless Steel Bottom Freezer...
Refrigerators Logo
393 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
