Question about E-Machines eMachines Desktop PC
Emachine flashing yellow lights, fans power up when P8 is unplugged
I was given an Emachine T2542 that went out. It won't power up and flashes yellow around the power button and the other light on the front but no fans. I unplugged everything from the power supply and individually started plugging them back in starting with the P1 (motherboard). This allowed the fans to start up. Once I got to the P8 (4 prong that attaches to the motherboard) the fans stopped. I'm not sure what this is for. I was told that the flashing lights could either be the power supply, power button or motherboard. I tried installing a new power supply but it did nothing at all, even when I plugged them in one at a time. The fan started when we did the paperclip test in 14 and 15 of the motherboard connection so it apparently works. What do you think it could be?
  • AASessions Jul 06, 2008
    Thanks for the info. The old 250 power supply worked with it for 5 years and just went out so it was powerfull. The fans both turn on when I plug in the 20 pin to the motherboard. When I plug in the 4 pin CPU power connector, the cpu fan shuts off but the power supply stays on. There is no on/off switch on the old PSU. The new PSU is a 350 and it will not power up anything. Nothing works, not even the lights. I went through everything with a tech and we narrowed it down to the motherboard. I will be switching it out with a better one with a better CPU but $65 on Newegg.
  • thubbartt Jul 19, 2008
    This T2542 emachine power problems: replaced motor , and when turned on fan went on for 5 seconds and all turned off again. flashed green then yellow initially but shut down. I am new to these older machines but need to see a diagram of how to start unplugging what to track down the problem.
I would also suggest that the battery in the motherboard be replaced.That battery is startup power for the computer and if the battery is dead you will have the same symptems of startup power problems!!!The battery you will be looking at looks like a large watch batteryand is flat slide the old one out and replace it with a new one and it should solve your issues!!!
Posted on Aug 21, 2008
    Novelist:
    Scholar:
  • 141 Answers
Did some research and found this site which will tell you which pins to test. It is possible also that its not powerful enough for the devices you have. I would try again only giving power to the motherboard pins, of coarse and the hard drive. If works then plug one device at a time.
Good luck
http://articles.techrepublic.com.com/5100-10878_11-1046822.html
Posted on Jul 05, 2008
  • Theresa  Smith
    Theresa Smith Jul 06, 2008
    Good luck
    http://articles.techrepublic.com.com/510...
  • Theresa  Smith
    Theresa Smith Jul 17, 2008
    Please be careful when installing a new power supply. System must be off and unplugged. Insert 20-24 pin on mother board then 4 pin plug on mother board first followed by drives and cards. DO NOT disconnect any power plugs or devices or device plugs when computer is powered up.
    You must turn off system each time your disconnect a device or plug from the mother board as well as power off when connecting new devices.
    Connecting the 20-24 pin and powering up without the 4 pin connected to mb can cause serious problems. Both must be plugged in before switching on power.
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
Emachine locked up won't start
Hard Drive Clicking = Going Towards End Of Life
Put the hard drive in a working pc and get any important data off it , its about to die!!!!!!!
Get a new hard drive and do a windows reinstall (not like you have a choice)
not sure about the rest though sorry
Jan 04, 2009 | E-Machines eMachines Desktop PC
Emachine t2542
When you say out, do you mean they are broken, or just disconnected? Most of these computers have a plug on the end of the wires to the front panel and it just plugs into the system board. If you look at the board you'll see where the front panel wires go. Sometimes it's hard to read the small type, but there are labels on the board that tell you what connector does what.
Nov 17, 2008 | E-Machines eMachines Desktop PC
T2542 Emachine
It's hard to troubleshoot a power supply. They are very dangerous and contain electricity for some time after turned off. If your new one isn't solving your problem it makes me think it's not the power supply unless it's not powerful enough. Try this:
Open your case having your "CPU & HEATSINK" in sight. You can lay your case on its side if its easier to see this. Power up watching only the cpu fan located on or in the attached device over your processor (cpu). If it doesn't turn then that is likely your problem. CPU is overheating which automatically shuts down system. Pls. make sure both 20-24 pin and 4 pin plugs from power supply are tightly plugged in mother board before you start.
If it is working try another power outlet in your house. Sounds odd but is a known issue.
Could be a few more things but these are most common.
Let me know pls. your results.
Jul 19, 2008 | E-Machines eMachines Desktop PC
My T2542 won't start.
There might be a problem with your mother board, or processor, or both of them.
Oct 07, 2007 | E-Machines eMachines Desktop PC
It wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Sep 20, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
E-Machines eMachines Desktop PC Logo
741 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
