My cd tray is stuck. it will not close nor will it open all the way. what happened to it? how can i fix it. can you help
    Genius:
  • 2,785 Answers
The gear of the rom is having problem, it will be better if you purchase a new one
Posted on Jul 05, 2008
Cd tray closes quickly without pressing switch on Technics SL-pd688
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Jun 19, 2014 | Technics SL-PD8 5-Disc CD Changer
Cd tray won't stay open--when you press the "open" button, it opens but then closes again immediately.
It has a misaligned loading mechanism. I have dealt with this kind of problem before. What is happening is that before the tray have a chance to open all the way it gets stuck and gets pulled back in.
May 24, 2011 | Marantz CD5001 CD Player
My Lite-ON Combo SOHC-4836V DVD/CD-RW Drive will not open, is there any way to fix this? Expected Action: CD Tray opens What Happens: The sound of it trying to open, then the sound of it closing....
It sounds like a mechanical failure of the drive tray.
Use a un-bent paper clip and stick it in the tiny hole near the tray of the drive to attempt to prod the tray out of the drive.
Most likely there is something (a CD probably) stuck in the drive.
It may take a good deal of jiggling and bumping of the drive to get whatever is blocking it to come free. Be patient but firm.
Dec 31, 2010 | eMachines W3506 PC Desktop
Th cd are getting stuck in my gpx kccd6316dt, I
Is it still under warrenty?
Either it is worn out or it has a manufacturing defect.
Mar 24, 2010 | GPX KCCD6316DT Shelf System
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
Sep 25, 2009 | Sony CDP-C910 10-Disc CD Changer
DVD Tray in computer not opening
there should be a small hole on the front of the tray that you can push a pin in from and it will eject the tray. if its stuck and you still need to hit it, would be best to use your warranty to get it fixed or take it apart yourself and make sure noting is blocking the tray from opening. you may have to take the tray apart and put it back together to get it to work normally.
Jun 01, 2009 | Samsung Super-WriteMaster SH-S183L Burner
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
PS2
There may be many problem that have occurred to make this happen, here is a list of the three most common:
  1. You MAY have a disc jammed into the PS2, making it impossible to open (and/or) close. This could have happened by someone accidentally putting one disc right on top of a disc that is in the PS2, and not taking the other game, movie, etc., out. How to fix? Best Buy, Circuit City. Another way this could have happened is: an earthquake, flood, SOMETHING, may have happened that made a disc fall out of the tray (while INSIDE of the PS2) and jam it up, to fix this, you have to do the same as the first option.
  2. The motor is broken, this is pretty self explanatory, the motor that makes the disc drive open and close is broken, solution? Same as before.
  3. Your PS2 has reached it's prime, and gone over the hill, sorry buddy. :(
I hope you found this helpful, sincerely- animation508 (youtube username)
Sep 23, 2008 | Sony PlayStation 2 (PS2) Console
CD tray stuck
Problem is very simple, Switch off system, unplug from mains. Open the Cover panel, and remoove CD. Close machine. Plug into mains. Open Tray, put in anothrer CD, enjoy your music.
Mar 05, 2007 | JBL Harmony Shelf System
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
