Question about Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Can't find Satellites
Had mine for 9 months then it was unable to find satellites. Sent it back and they said they replaced the antenna. Three months the same problem. Reset does not work. Running down the battery does not work. I am 2 weeks short of 1 year old with this unit. Also problems with Upgrade availability not out until Sept 08. Despite the fact that Eastlink opened June 29th - the largest road infrastructre development in decades. Don't expect a Garmin to be any good.
A useless waste of money. The internet is full of problems with Garmin. Be warned about this products inability to find satellites.
  • spalding1960 Jul 06, 2008
    I've had this unit for 11 months and it starting acting up two weeks ago. Says it cannot find satellites and then all of a sudden it starts to work. Then I loose it again, very unreliable for what I need. I hope it can be fixed under the warranty.
    Scholar:
  • 40 Answers
Try this and see if it fixes your problem...first disable bluetooth then follow these steps....
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Posted on Jan 02, 2009
Maybe you are right.. I have a Nuvi 250 and exactly the same problem.. Only I bought it in Perth and unable to do anything in Sydney so far.. Will try once more today. My warranty is up next month! Wish me luck!
Posted on Jul 05, 2008
Receiver Garmin nuvi not acquire satellites i lost satellites signal
Common problem. Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Aug 21, 2011 | Garmin Nuvi 660 GPS Receiver
CANNOT GET SATELLITE POSITIONING ON MY NUVI 1340
What do you mean program in the satellites? There is nothing to program for that, unit will when powered up and with a good clear site line to the sky will usually find and access the satellites on its own. If you are looking for the gps satellites they will already be programmed into the unit, if your looking for different satellites, well you got the wrong tool for that.
May 10, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin 660 unable to locate satellites. When it does, very unreliable
The flip up Antenna/GPS receiver board needs to be replaced. Please see this link for more info. To much to cut and paste here.
- Jim
Aug 09, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 cannot acquire satellites
Hi I had this problem and its an antenna fault, give garmin a call and see if yours is still under warranty, if it is they will tell you to take it back to the retailor who will call garmin for a RA Number and they will replace it there and then. If your warranty has run out then call garmin to ask about repairs
Best Of Luck
Jul 19, 2009 | Garmin Nuvi 660 GPS Receiver
Satellites not found garmin 755
is it getting to the satellites?
if not improve the battery level by charging properly.
Jul 06, 2009 | Garmin Nuvi 660 GPS Receiver
My nuvi 660 all it says is acquiring satellites
Try reuptdating your GPS or reset it it might be a bad patch.
Jun 23, 2009 | Garmin Nuvi 660 GPS Receiver
Acquiring satellites
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin Nuvi 360 lost satellites during use and can't locate
I had the same problem with mine...I shut it down and left it off while giving it a full charge...
Jan 14, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin 680 -cannot acquire satellites
Im not 100% but im thinking that if the ribbon connecting the reciever to the unit can become dislogged or damaged, im trying to find a replacement ribbon.
Jun 24, 2008 | Garmin Nuvi 660 GPS Receiver
Unable to acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} My Gamin Nuvi 660 Solution
External antenna - Garmin 25MCX low profile remote GPS antenna
I have been experiencing the same problem many have been having with the Nuvi 6xx and 3xx series giving an error message “Lost satellite reception”.
My problem started mid April 2008 and got progressively worse. I would use my GPS on weekends and it would work perfectly for the first 10 – 30 minutes and then would loose satellite reception, rendering it useless.
I bought my Nuvi 660 when it first came out in October 2006 for just under $700 and is now out of the 1 year warrantee.
I called Garmin Technical Support and we checked my Software version (4.40) and more importantly my GPS SW version (3.00). According to the tech I had on the phone, the GPS SW version was more important then the Software version. It was in fact already updated to 3.00, I did master reset, after master reset, but regardless, nothing helped.
I contemplated what I should do.
Return mine and get a refurbished unit from Garmin for $225 with only a 90 day warrantee?
Buy a new Nuvi 660 for around $300
Buy a new Nuvi 2xx series with fewer features for $200 to $275.
Buy a Megellian GPS?
I read through this forum and came across one person that was told by Garmin “that they are aware of an issue with some Nuvis involving the failure of a diode in the unit that senses whether or not an external antenna is connected.” Apparently this diode failure is caused from the high heat these units experience from being left in a hot car for long periods of time. This would explain why mine would work in the beginning and then die.
So my thinking was, if the diode “thinks” there is an external antenna attached when it isn’t, what would happen if I “did” connect an external antenna?
Garmin recommends the Garmin GA 25MCX low profile remote GPS antenna for the Nuvi 660 and costs $31.49 (not sure about additional costs for tax and shipping)
So I purchased the NEW antenna from a seller on eBay for $25.90 total and IT WORK FLAWLESSLY.
Just to make sure it really was the new external antenna that was working and not the unit coming back to life, I started my 3 hour journey with the external antenna NOT connected. As usual it lost satellite reception in about 15 minutes. I plugged in the GA 25MCX and it immediately connected to the satellites and never lost them.
I repeated the same process coming home and once again, I connecting the external antenna after the unit reported loosing satellite reception, and it worked perfectly.
Conclusion: if your unit is experiencing loosing satellite reception, and is under warrantee, return it ASAP. If it’s out of warrantee, get an external antenna. There are other manufactures of external antennas and all should work as long as it has an MCX connector.
Side Note: This external antenna also worked perfectly on a friend’s Nuvi 350 with the same problem.
I wanted to share this with everyone because I’ve been racking my brain for months over this. I hope this helps.
May 04, 2008 | GPS
Garmin Nuvi 660 GPS Receiver Logo
1,990 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
