Question about Baby Bjorn XL Baby Carrier
Missing Piece In the part of the carrier that has the anchor, one of the plastic inlay pieces which slides in the other part of the carrier fell out and is lost. The remaining side has a blue inlay plastic piece. Is there a way to get a replacement so that the carrier is fully functional? Thanks, Edward
  • 23 Answers
Try contacting Baby Bjorn direct (www.babybjorn.com) or popping into a local Baby Bjorn stockist, who should be able to order in the spare part for you for a small fee.
Posted on Sep 17, 2009
How do I remove the Main PCB from an LG LMU24CHV note not 247HV
Very easy. Use knoseplayer and hold both broken plastic together and then slowly remove ur board. Tnq
Sep 02, 2015 | LG LMU247HV Air Conditioner
Frigidaire Gallery Microware door doesn't latch
I experienced the same problem. The solution was easy, for me at least. Remove the door. pry loose the plastic liner that covers the inside of door. remove the four screws that hold the glass unit in place. You will find rattling around inside a spring about an inch long and a broken plastic piece about an inch and a half tall. On my unit the plastic piece was still hanging on by a thread which gave me a clear understanding of how the door latch is supposed to work. Remove the plastic latch unit which is designed to slide on the two posts about three eights of on inch distance under the pressure of the spring. Problem is loss of spring induced pressure.
The repair: ( I used my bandsaw to do this) fashion a piece of wood with indentations that correspond to the plastic ribs enabling the wood to sit perfectly into the space. Drill a hole at the point where the inch and a half "anchor post" broke off and insert a dowel of same length. I carved a shallow indentation for the spring, pressed the spring on with needle nose pliers, replaced the sliding latch mechanism, attached other end of spring to the latch. I drilled into the exterior plastic door frame and installed a flat head screw to hold the wood repair piece solidly in place. Re-install pieces removed earlier and you have a happy, functioning Frigidaire gallery micro at your service. Took an hour.
Apr 06, 2014 | Frigidaire Gallery FGMV174KF 1.7 cu. ft....
I too am having a problem removing the small metal piece from the back of my 2002 pontiac grand prix rear view mirror. It fell off the windshield due to the heat, I'm supposing. It has the Onstar...
It should be the same as the ones from the late 90's. You have 3 pieces there. The metal piece comes out the bottom of the mirror and should have a piece of plastic attached to it. It is a friction fit with the actual mirror so it shouldn't require a lot of hammering or even hard hammering.
Once the mirror is off there should be a small slot in the remaining plastic and metal. Use a small screwdriver or something similar to push in on a clip that is inside and the plastic and metal should separate. Hope this helps.
Aug 10, 2010 | 2002 Pontiac Grand Prix
A rubber piece fellout and there is a white wire hanging out.
This just happened to me.
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Mar 02, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ther top spray arm fell off the dishwasher
THERE IS PROBABLY A BIG PLASTIC NUT THAT IS STILL SCREWED ON THE UPPER TUB.THIS WILL UNSCREW AND WILL COME AS ONE PIECE IN A KIT.
Mar 01, 2010 | Frigidaire Dishwashers
Oster Power Pro Cordless Clippers I took the blade off, sm. long black plastic piece fell off. Wanted to change blade to ceramic. Can't get it back together don't know where black piece goes. Don't know...
The plastic piece is a blade guide and has a slot down the length of it which the spring locates into. Simply slide the replacement ceramic cutter under the spring
Sep 29, 2009 | Oster 76076-010 Hair Trimmer
I realized that my GE washer was not spinning because the lid actuator pad is missing. I can pull the hook to make it work, but it needs the pad. They cost about $30 for a small piece of plastic! Is...
all that lid pad is ;is a strong magnet in plastic. find a strong magnet in a craft store. fridge magnets wont work they arent strong enough.
Sep 12, 2009 | GE Washing Machines
Missing piece, camera will not turn tape
the pinch roller goes here:
you are missing the snap spring too, which is used to lock the pinch roller.
May 21, 2009 | Sony Handycam DCR-TRV240 Digital Camcorder
Installation of a new top spray arm
should only be a little plastic push in clip facing down towards the dw in the middle of that spray arm. should be able to pop it out. you may need to take the supply tube off the back so you can get a good look at it
Nov 21, 2008 | Dishwashers
Baby Bjorn XL Baby Carrier Logo
163 people viewed this question
Top Baby Bjorn Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Bjorn Baby Gear Expert? Answer questions, earn points and help others
