Question about LG Flatron F700P 17" CRT Monitor
AOC MONITOR PROBLEM
My aoc crt monitor has no high VOLTAGE even connectec to the power line and cpu what would be the solution to this.
SOURCE: AOC color monitor model 9g1rs, dead, ** volt, fuse good
Hi
You need to replace HOT(Horizontal Output Transistor) see number carefully before you replace it.
Posted on Mar 18, 2008
Democritus
  • 120 Answers
SOURCE: hi...my AOC 17" CRT monitor
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Posted on Dec 12, 2008
SOURCE: AOC model 1770 cable conexion
DIAGRAMA DE CONECTOR VGA
Posted on Jan 07, 2009
  • 400 Answers
SOURCE: My Monitor AOC CRT Model F1770 is always adjusting
Try to unplug the power cable from the mains for about 10 minutes then replug and try again.
Make sure all cables are well connected.
Try to test it on another computer if possible.
If that doesnt help then it sounds like a hardware problem with the monitor and you wont be able to repair it your self.
Posted on Jul 24, 2009
  • 3 Answers
SOURCE: no power dead set 5en aoc monitor
just try to change the horizontal transistor C5386 or CXXXX... with a new one....
Posted on Aug 30, 2009
My aoc monitor 2216sw shut down after three seconds on
It sounds defective. When the high voltage power units stop working; you will experience this type of problem. I would call AOC and see if the monitor is under warranty. Otherwise, seek an alternative monitor to use.
Jan 06, 2011 | AOC 2216SW Monitor
One line on screen
If the line is horrizontal then the fault is in the vertical deflection circuit.
It is not worth repairing an old CRT monitor, unless you have electronic knowledge. I do not recommend repairing CRT monitors yourself, because there are dangerous high voltages inside these monitors, even though the unit is unplugged from the main outlet. The CRT tube will hold high voltages for weeks even though the monitor is turned off.
I suggest you put your money towards a LCD screen, they are inexpensive.
Nov 02, 2010 | LG Studioworks 700S 17" CRT Monitor
Moniter display problem pls help me? single line in the moniter centre ?
Aug 25, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
AOC color monitor 15in. 5En model. during power on all led lights functioned and no display was observed
u try to reorient ur vga connection it might be a loose connection between ur monitor and ur cpu otherwise ur vga cable is defective...
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Aoc1770 monitor
I disconnect the cable that connects the CPU, the cables came off, I need the connecting diagram for the monitor AOC 1770, the combination of the cables in the connector to the CPU, thanks
Dec 16, 2007 | AOC CT700G 17" CRT Monitor
Monitor Repair
Dec 14, 2007 | AOC CT700G 17" CRT Monitor
LG Flatron F700P 17" CRT Monitor Logo
73 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
