Question about ASUS P5PE-VM Motherboard
Booting up new motherboard
When I start my computer up after installation of new motherboard and hard drive, I get the following message after the computer goes through the start up check. Reboot and select proper boot device, or insert Boot media in selected boot device and ;press a key. Trouble is everything seems to be properly selected and when I enter setup it all appears to be set as the manual displays. Boot media did not come with the new motherboard I had purchased and installed. I am lost for solutions. Help!
  • johnniefunki Jul 05, 2008
    The boot is set as was suggested, but I still come up with the message of 'Reboot and select proper boot device or insert boot media in selected boot device and press a key'.
    All of my connections are as perscribed. All jumpers are installed and both CD/WR drives are installed. Everything checks during start up except I keep getting the same messege. 'Reboot and select prper boot device or insert boot media in selected boot device and press a key'. All setups are as the directions in the manual for the new P5E-VM HDMI motherboard and Intel core tm2duo processor and MAXtor hard drive. Nothing has worked from the suggestions so far.
    President:
  • ASUS Master
  • 1,314 Answers
Try disconnecting all the other drives except the hard drive. Make sure the hard drive is on the primary IDE or the first SATA channel. You should then at least get operating system not found unless the hard drive already contains an operating system. Once you get there, then connect one optical drive up. From there you can install your operating system.
Posted on Jul 05, 2008
    Guru:
  • 1,342 Answers
You need to install an Operating System on the hard drive in order for it to boot. If you haven't yet set your first boot device to CD and reboot with your OS installation CD in the CD drive.
    Scholar:
  • 83 Answers
The computer will attempt to boot (load an operating system) from any disk drive specified in the Bios, in the order these devices are listed in the Bios. This error occurs because a drive that does not have a bootable operating system (the external drive) has been placed before the hard drive in the search order. If the drive is not switched on, the computer does not see it and therefore does not try to boot from it. You have to make sure that the computer knows to use your internal hard drive with your OS to boot.
Do You have an external drive connected to your computer? Or some other device like a flash drive attached to the computer?
When you start the computer and the external drive is switched on, an error message is displayed: "Reboot and select proper boot device or insert boot media in selected boot device and press a key."
If you have an external drive, switched it off whenever you start or restart the computer.
Change the order of the boot devices.
Enter Bios Setup (this is done by pressing a key as requested during start-up)
Select the Boot menu (or similar)
Select Boot Device Priority (or similar)
Change the device order so that the external drive is listed after the hard drive, or remove it from the list of bootable devices altogether. The main hard drive should be the 1st boot if you have more than one.
  • Shaun Harris
    Shaun Harris Jul 05, 2008
    If your boot order is
    1st. floppy - it will try to boot from this 1st
    2nd - cd rom- it will try this next
    3rd HD - IT WILL LOOK FOR THE BOOT FILE HERE.
    ALSO MAKE SURE NOTHING IS IN THE FLOPPY OR THE CD/ROM
    If you don't have an external or flash drive connected just
  • ASUS Master
  • 6,487 Answers
You need to check that your media like CD-ROM is in a proper jumper settings because it not being detected by your pc check this link http://www.mysuperpc.com/pc_assembly/computer_install_cdrom.shtml
then try it again.......
Hope that helps........
    Guru:
  • 859 Answers
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
  • Glenn Rogers
    Glenn Rogers Jul 05, 2008
    If you are still stuck here, your board may support the F8 Boot Select source option. Bootup and instead of pressing Del, Press the F8 key by tappnig on it until you are given a choice of boot source options. Choose Hard Disk 0. This assumes you have your hard drive(s) mounted on the cable correctly and pinned for CHS or Cable Select.
    You can also bootup with your WindowsXP disc in the CD/DVD bay and choose to startup with repair console. From the command prompt, type Help. You will see commands to fix several things such as MBR and BootSector.
    But, to be honest, if this is the first motherboard you've installed, the chances are quite high you have done something wrong.
Hi, I can not install Windows XP on my computer. After booting from CD it start to loading for driver then when message come at the left bottom side that "Setup is starting widows" but never...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 06, 2011 | Intel DG31PR Motherboard
Hi I'm having problems installing windows 7 on my computer I think it may have something dealing with my motherboard I m running a MSI P55M-GD41 mother board with intel i5-661 processor and 4GB of 2 2GB...
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Oct 24, 2010 | MSI P55MGD41 Motherboard
When installing xp on new hard drive in a gateway GT5056 it says NTLDR is missing What does this mean
If you are attempting to install Windows XP and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
When the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Aug 16, 2009 | Computers & Internet
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
Xp pro set up
copy ntldr file from i386 folder and paste in C:\
steps
  1. Use the Windows Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears:
Feb 22, 2009 | Microsoft Windows 98 for PC
Problem of Window XP installation
usually when installation of windows fails is from more than one reason and lets hope that ur hard drive is not damaged (contains bad sectors).
try these steps :
1- use a different windows cd and a different cd rom if u can find one.
2- change the sequense of drives by changing their jumper positions and data cables ( master, slave)
3- try to clear cmos with the jumper located usually near the mainboards battery (short it for 3 seconds)
4- try ( low-level format) to ur hard drive and reinstall windows.
if the message is still seen then your hard drive could be seriously damaged.
May 28, 2008 | Intel Motherboard
CMOS SETTING and BOOTING
I just had the CMOS checksum error while starting the computer, So pressed F1 and continued.. I just don't think it's the battery, because the computer is 2-3 months old, and all parts were new. I also have another problem. which is that it tells me at start upo the the IDE 80 connector cable isn't installed, or something like that, which prevents one of my hard drives to be found by windows....
Dec 18, 2007 | EliteGroup K7AMA Motherboard
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
ASUS P5PE-VM Motherboard Logo
395 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
