Question about GPS
Coby mp3 i plugged the device into my computer and a window came up that the computer does not reconise the product connected inserted cd and nothing happens what do i do
By not supporting u when it says FREE
Posted on Jul 06, 2008
I just got my Coby Mp3, and i plugged the USB into my computer and the autoplay screen that is supposed to come on my computer, hasnt.
Does you computer detect a new device when you plugged the Coby MP3 player?
If Coby MP3 player has cd driver, better to install it to your pc. Some computer/laptop doesn't detect autoplay when new USB device plug-in
May 07, 2011 | Coby MP828 MP3 Player
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
Feb 21, 2011 | Coby MP-30523 MP3 Player
I have a spi 2gb mp3 player and have lost the software disc i cannot find anything online to help me and the tech support for the spi site goes to an unbought site for godaddy.com this is ridiculous. win 7...
Try another computer (if available) to see if the player is reconised by that one. If it is reconised, there may be something wrong with your computer (windows should still reconise the device as a mp3 player, but would not be able to open it without the drivers). If you can't try another computer, try a linux live cd (I recomend Ubuntu http://www.ubuntu.com/) the live cd will not modify your computer unless you tell it to. To use the live cd insert it in the cd drive, reboot and in the bios menu select boot from cd. Using the live cd will allow the computer to run linux (another operating system) without installing it, meaning that you won't need to worry about iharming your computer. I reccomend this because if you use the live cd, you will have a different OS looking at the device, like having a fresh set of eyes, and it may be able to open the player (Ubuntu has great driver support).
Jul 18, 2010 | Computers & Internet
This came with no software and i cannot seem to put any music or video on this mp3 player why
When not having the installation CD at your disposal, for support select
MP3 & Portable > MP3 & MP4 Players > MPC7085 in this page:
http://www.cobyusa.com/?p=doc
Start with the MP-C7085 setup guide:
http://www.cobyusa.com/files/setupguide/MPC7085_SG.pdf
More information about the device in MP-C7085 manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Software Coby Media Manager for the computer:
When running Operating System Windows 2000/XP/Vista:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0924.exe
When running MAC OS X10.4 or later:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0814.dmg
For a download right click the matching software and select "Save Target As..." to a location on the computer. Run the software by double clicking it.
When running Coby Media Manager select Tools > Device Manager...
to select the MP-C7085 from the list, Add and OK for this player setup.
Need more help ? Just post a comment.
Jan 04, 2010 | Coby MP-C7085 MP3 Player
I just bought a Coby MP600-4G MP3 player. but it doesn't show in my computer.
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.
Dec 28, 2009 | Coby MP-610 MP3 Player
The MP3 isnt read on the computer
in the connectivity cable.plug your device on the cable.
Dec 28, 2009 | Coby MP725Digital Media Player
I need some instructions on how play it
1. Use Windows Media Player to put songs on your Coby MP3 player. Download songs in MP3, WMA, or OGG format from a legal downloading website. If the file is not one of the previously mentioned files, you must download a converter to convert the file to one of the correct files that can be played on Windows Media Player. Rip a song from a CD by inserting the CD and then click on the option to "Rip" the song to your library. Some Coby MP3 players do not need Windows Media Player to add songs, so be sure to check your user manual to see if there is an even simpler method.
2. Connect your Coby MP3 player to your computer using the USB connector that came with your MP3 player. The player will show up under the "Devices" option on your Window Media Player application.
3. Click on the "Library" option to view all of the songs stored on your Windows Media Player library. You can drag the song to the MP3 player in the "Devices" section, or you can right-click on the song and choose the option to transfer the song. In the pop-up box choose your MP3 from the drop-down menu and then click on the "Transfer" button.
4. Right-click on the MP3 player in Windows Media Player and choose the "Eject" option. Disconnect your MP3 player from your computer and turn it on. The song will now be available on your MP3 player. Press the bottom button to play or pause the song.
5. Add videos and pictures to your Coby MP3 player if it supports those files. The process is similar to transferring audio files. Plug your MP3 player into your computer. Open the photo file on your computer and drag pictures into the player. You can create folders to organize the pictures.
Sep 30, 2009 | Coby MP-C552 MP3 Player
Coby mpc896
Link for generic USB drive if you have Windows 98:
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
If you have Windows XP, installation cd is not required, you just plug the unit into your computer, the computer will automatically recognize the device.
Aug 22, 2008 | Coby MPC895 MP3 Player
Computer doesn't recognize unit when connected
I am guessing there is a problem with the driver for the audio player. I have a Coby Audio Player MP-C827, and one day my brother decided to just remove it from the computer without correctly stopping it. Ever since, whenever I plug in it into my PC, it just does not open...nothing happens. And I don't have the cd to re-install the driver files. With respect to all of the above, a driver file which is needed by the mp3 is either damaged or corrupt. Contact me at ramone.williams89@gmail.com
Dec 29, 2007 | Coby MPC-848 MP3 Player
GPS Logo
21 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
