Sony Receiver Str-av370 ... The red "P"
I'm begging you to help me with this strange "P" flashing that freezes the receiver. Then, when i turn it off, the surround light is flashing again with a click kinda noise. Thanks!!
  • 1 more comment
  • mark_enting May 01, 2009
    I have the same problem, everytime i turn my STR-AV220 on the red P is blinking. It's only getting away when the power is cutted for about 30 min.
    Please notify me when a solution is offered.
    Mark.enting@hotmail.com
  • karthikey297 May 04, 2009
    "Sony Receiver Str-av370 ... The red "P"" problem, and notify you when a new solution is offered.
    how will solve the problem
  • tomi tams
    tomi tams Jan 17, 2018
    hellosztok segitsen m?r valaki nekem is ez a probl?m?m hogy egy sony STR-AV220 tipusu r?dio er?sit?m bekapcsol?sn?l ugyan a piros p jelenenik meg, el megy a hang le fagy csak ujra kapcsol?sn?l szol ?jra tud valaki megold?st ???????
I have the same receiver and i also have the same problem,
this happens when i turn the volume or the bass too loud.
it suddenly clicks and the sound cuts off. then the flashing red P appears.
My solution: As soon as it happens, quickly press the power button twice (turn off, turn back on)
and turn the volume knob all the way down. wait 2-3 seconds and it will click back to normal.
If you take too long before turning off the receiver when the P appears it will not work.
In this case you have to unplug the power cord and let it rest for at least 20 mins then plug it back in.
hope this helps!
ps: I've been using this receiver for mure than 8 years so i'm quite used to it!
Darkstarr
Posted on Oct 24, 2008
  • justlookatthatsuckergo Dec 03, 2011
    Thanks Darkstarr ... my sister just phoned me with that problem, she pushed every possible button and it was still frozen with the "P" and the same clicking noise when switched off (but still plugged in) that 'philclab' described. So I googled, we tried your solution, and it worked. We turned the volume way down first, then clicked it Off/On quickly, and first time it didn't work, second time it did. Funny, we had tried unplugging for 10 minutes, but the Vol was at about 1/4, you'd think that would be okay, but evidently as you pointed out it is important to have the Vol turned way down. THANKS!
You need:
a phillips head screwdriver
unplug unit and discharge any static electricity.
remove the metal grill/cover to expose the internals.
there's a cord that is connected to the LED display with a screw, tighten said screw.
this should fix your problem
Posted on May 19, 2009
  • tomi tams
    az a baj hogy nem l?tok ijen csavar sehol amit meg k?ne huzni vagy kihuzni???
I have the same model and had the identical problem. If you can take it to an audio tech it is a simple fix...there is a bad solder joint/joints that is causing the unit to go in to protection mode. He just had to reflow the solder on the offending part/parts. If you like the receiver,the fix may be worth it....mine was well under a hundred bucks. Hope this helps!
Posted on Nov 02, 2011
Sony receiver stR se-501 found fuse burned after replaced turned on the flashing massage PROTECT come on . Did I miss anything?
Protect typically means that the fuse blew because something in your receiver went bad. It's now protecting your speakers from that badness. You need to get the receiver fixed or replaced.
Jun 16, 2015 | Sony Str-Se501 Stereo Receivers
How do I connect my turntable to a str de-675 receiver
Take 2 rca wires a white one and a red one. On the back of the receiver, find a source you are not using( md/tape or aux ) connect red to red, white to white Turn on receiver and on the front, push related button( aux ). This should work. Good luck
Feb 10, 2015 | Sony STR-DE675 Receiver
STR-DG520 receiver will not power up
hello it sounds like it could be a capacitor problem or a leaking transistor
regards
shaun
May 27, 2010 | Sony STR-DG520 Receiver
I have a sony receiver that keeps flashing "protect" what does that mean
hello it sound like the output transistor could have blown or a capacitor could have poped or bulged
regards
shaun
May 15, 2010 | Sony STR-DE475 Receiver
How do I connect my ipod to my Sony STR-DE585 receiver
Use analog audio cable with jack connector on one side (to the iPod) and 2 RCA connectors (white/red) on the other end for the analog inputs of receiver.
Feb 07, 2010 | Sony STR-DE585 Receiver
Sony Model: STR-DG800
You've got a short in one of your speaker wires either at the receiver (most common) or at the speaker itself. you should only have a 1/2" of each side of the speaker wire stripped to put on each terminal, and when you strip them, twist them so there are no frays in the strands that will touch the other terminal. The receiver is protecting itself from harm. Turn it off then disconnect all speaker wires, examine each wire carefully before reinstalling, then turn the receiver back on. If it still says protection, look at each speaker and reconnect your wires the same way. If you still have a problem, disconnect the wires again at the receiver and turn on, at this point, if it say's protection, it needs to be serviced. Hope this helps
Jun 23, 2009 | Sony STR-DG800 Receiver
"PROTECT"flashing, no response, STR-SE391
The audio amplifier IC are fried and need to be replaced
Feb 06, 2009 | Audio Players & Recorders
My Sony STR - DE310 flashes PROTECT
remote volume control is broke.
Dec 22, 2008 | Sony STR-DE310
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Nov 28, 2008 | Sony STR-D665 Receiver
Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
4,196 people viewed this question
 Grubhead
Grubhead
