Air conditioner compressor will not come on - Heating & Cooling
  • Aldo0 Jul 09, 2008
    Air Conditioner is on but the compressor will not turn on it keeps kicking on and off please help soooo hot in her :S
My problem was the capacitor. Replaced and worked fine after that.
Posted on Mar 21, 2009
System is low on freon you have a leak call a repair service
Posted on Aug 03, 2008
Compressor not running.
Haier Air Conditioner Compressor
modernemporium.urizyme.tk/512124/haier-air-conditioner-compressor
Using a ohm meter, and the compressor is cool to the touch, and the ac is unplugged, Disconnect the wiring to the ... Failure rate on compressors so far not including. ...Haier 12,000-BTU Energy Star Window Air Conditioner with Remote ESA412K-L. Consumer complaints and reviews about Haier Air Conditioner. Since air .
Jul 21, 2015 | Haier ESA412K Window Air Conditioner -...
Hi Just wondering if you could tell me some troubleshooting ideas for an Amana air conditioner--it seems to be getting power--we are hearing a noise coming from the unit indicating that it is getting...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
To start a compressor you need a start contactor - relay and a capacitor. The click you hear could be from the contactor, which could be normal OR could mean that the contacts are not staying closed which would not allow the compressor to start.
Jul 22, 2011 | Amana Heating & Cooling
I have a small frigadare a/c.a one room a/c.it comes on then right back off.what can i do about this.
Hello, here is what the problem may be. Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
May 25, 2011 | Frigidaire Heating & Cooling
Breaker keeps tripping when the compressor comes on
Either the capacitor is bad and the compressor is not starting or the compressor is shorted internally and it is causing the breaker to trip....my but is on the compressor... a good guy with an OHM meter can check it out and tell you in a few minutes...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Oct 25, 2010 | Goodman CKL60AR60 Air Conditioner
Air conditioner fan run,but compressor makes popping soun
Go buy a new a/c unit as the compressor is locked up in all probability and if the sealed system has no warranty left.
May 28, 2010 | Whirlpool ACC108PS Air Conditioner
Wont blow out cold air anymore?
hi...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner...
hope this will give u a clear idea..
thank u
rate me!!!!
Jul 19, 2009 | Pelonis Heating & Cooling
No cold air
hi..
The evaporator coils on the front of the air conditioner get very cold during normal operation of the air conditioner. As the warm moist air in the room comes in contact with the cold evaporator the moisture in the air condenses out of the air and attaches to the evaporator coil. As more and more moisture condenses the water begins to drip down into the base of the air conditioner where it is evaporated to the outside of the house.... so the problem might be in ur evaporator coil.. try replacing the coil if u are an expert or else with the help of technician try to fix it..
Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
Compressor
Condenser
Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
Compressor
Overload and/or relay
Thermostat (Open thermostat)
Burnt wiring
Bad selector switch
Capacitor..
Jul 02, 2009 | Campbell Hausfeld Maxus 30 - Gallon Air...
Air condition problem
What type of thermostat do you have? If the fan is not coming on and neither is the compressor, then is more than likely a problem with the thermostat of control units of the Air Conditioners. The fan will come whether the compressor does or not if the thermostat and control unit are working correctly. Check for twelve volt at the control unit of the air conditioner ceiling unit. (Red Wire, should be labeled)
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner keeps tripping breaker replaced the termostat do you think the compressor is gone its only 6 years old.
if this helps please vote me a fix ya
Jul 18, 2008 | Heating & Cooling
Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
Heating & Cooling Logo
383 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
