Just purchased pixmamx310 office all in one. I am stocked on step 7 on page (start here). the machine keeps flashing and never stops. !!!!!!! what is the time requirents 1 hour? 2 Hours???
Set up CD-Rom won't download onto my computer
Posted on Aug 26, 2008
How do i root my samsung sch-s736c by android
If you are lucky enough to have not updated and are still on the VRUAMDK Build number then here is the root method (source & credit given to: http://forum.xda-developers.com/showthread.php?t=2290798):
STEP 1: Go to the source link above and download the five items in the first step, Samsung Official USB Drivers, ODIN v3.07, VRUAMD2 Prerelease Kernel, Stock VRUAMDK Kernel for your phone, and Motochopper Root Exploit Tool.
STEP 2: Boot your phone into ODIN mode.
STEP 3: Flash the VRUAMD2 Prerelease Kernel using ODIN v3.07 in PDA section only. Boot back into Android and verify that the flash was successful.
STEP 4: Follow Settings -> More -> About phone -> tap "Build number" 7 to unlock Developer options and verify in there that you have "USB debugging" checked and "Verify apps via USB" unchecked. Verify in Security setting on your device that you have "Unknown sources" checked and "Verify apps" unchecked
STEP 5: Connect your phone to your computer and open "Run.bat" file from the location you have extracted motochopper to. You will see a message on the phone asking you to accept the new computer connection (select to always allow and select OK).
STEP 6: After motochopper runs and your phone reboots on its own, check if SuperSU has any update in the Play Store. Open SuperSU app and let the binary update itself to the latest VERY IMPORTANT OR YOU WILL LOSE ROOT ON STEP 4. Now you can open a root application and verify that is able to access root properly.
STEP 7: Now to restore the stock kernel you need to boot your phone into ODIN mode (how-to link above).
STEP 8: Flash the Stock VRUAMDK Kernel using ODIN v3.07 in PDA section only (follow same link in step 3 for a how-to).
STEP 9: Boot back to Android and verifying everything is still working and kernel has flashed successfully. You should now be fully rooted and on the fully stock original firmware that came on your device.
To restore a custom recovery (optional), follow Step 5 on the source link.
Nov 19, 2014 | Samsung SGH Cell Phones
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
What does LD code mean on my whirlpool cabrio washer mean?
Ld flashes when the water level does not change after the drain pump is on.
Is the drain hose or the drain pump clogged?
Is the drain hose height greater than 96? ?
Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom of the machine and the pumps. See Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Aug 20, 2014 | Whirlpool Washing Machines
I need a replacement film for my KXFP1o1 plain paper fax machine. Is this film still available? The machine is 12 years old, but works very well.
You should still be able to purchase this film. You need panasonic film part # KXFA65. I'm not sure where you live but if you are in Canada or the USA check Staples, BestBuy or Office Depot. I know Office Depot stocks them and they cost about $36 and should yield 330 pages. You can also buy them online from places like eBay for a price range of $12-$30.
Regards, Chris
Aug 23, 2011 | Panasonic KX-FP101 Plain Paper Thermal Fax
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
The application configurations incorrect
Title: Office installation
Step 1: Insert the Microsoft Office 2007 Enterprise CD. If the Setup Wizard does not automatically begin, then click Start > Run > D:\setup.exe
Step 2: Enter the Product Key from the back of the CD jacket. Note: This is a unique code. Please keep in a safe place! Click Continue.
Step 3: Check the box "I accept the terms of this agreement" and click the Continue button.
Step 4: Choose an installation option, Upgrade (removes Office 2003) or Customize (keeps Office 2003 installed and adds Office 2007, allowing you to use them both).
Note: Outlook 2003 will be uninstalled in either option. Outlook will be updated and your user settings and mail will migrate to the new version.
If you click Upgrade, go on to Step 5.
If you click Customize, go on to Step 4a.
Step 4a: Click the radio button for "Keep all previous versions."
Click the Installation Options tab, left-click the first drop down box and click Run all from My Computer
Click Install Now.
Step 5: Installation will begin. It may take 15-30 minutes to finish.
Step 6: Click Close to complete the installation.
Step 7: The first time you launch any Office program, you will be prompted to activate the software. As long as you have an active Internet connection, choose the default option and click Next
Step 8: When the activation finishes, click Close.
May 13, 2011 | Microsoft Office Professional 2007 Full...
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
jasbo
jasbo
