SOURCE: port forwarding? 2wire 2701hg-T
access your gateway homepage by opening your internet browser and typing this on the address bar: 192.168.1.254/management. then key in your system password and click on Settings under Firewall. there's option#2 (allow individual applications), click on "Add a new-user defined application", input the data and click submit another way is to enable DMZ plus mode. that option would actually make all the ports open. use this if option#2 is not working. after making the above changes refresh your router, just unplug then replug it from the power.
SOURCE: i have a xbox 360
check on the MTU settings of ur 2wire.
This are the steps to see what ur MTU setting is:
>connect a computer to the 2wire
>open Internet Explorer, Safari or Firefox
>enter this on the address bar: gateway.2wire.net/management
>enter ur system password (in case u forget this, click on i forgot my password to get a hint)
>look for Advance in the column on the left
>click on configure services
>on the bottom, u shud see the MTU number
** i searched online and accdg to xbox tech support, ur MTU should be in the range of 1364 to 1500 **
>click on submit after u change the setting
just in case youve entered the correct MTU setting but it still does not work, u might need to contact either xbox or ur internet service provider.
Keep me posted on this one.
SOURCE: Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
SOURCE: 2wire 2701HG-B: how do I extend it's range?
I purchased Netgear's Wall-Plugged wireless bridge (WGX102 ). Worked very nicely.
SOURCE: 2701HG-G firmware upgrade
Yes you can upgrade by buying the home networking package. It's $80. Otherwise you will have to upgrade your service. They're giving these modem/routers away free with upgrades.
or Found it...looks like my capped rate is 3008. that is their profile rate they've limited me to, or the maximum my connection can get.
twdsm.attenuation_ds = 61.03; % Only calculated during training
twdsm.attenuation_us = 31.50; % Only calculated during training
twdsm.margin_ds = 11.00;
twdsm.margin_us = 7.00; % Only calculated during training
it means you have down stream attenuation of 61.03%, up is 31.50%...
