Question about Panasonic DMR-ES30VS DVD Recorder/VCR
DVD recorder remote control wrong mode
Hi, I accidentally set the remote control of my Panasonic DMR-ES30V dvd recorder to mode2. I have previously used it mode 1 and everything was fine. Now i have limited use. Is there any way of resetting the DVD player because I can't get the function menu to come up on the screen now.
  • ian-dp Sep 02, 2008
    Hi, I have the same problem. Unit displays " Remote Code 2" while
    attempting different functions. Tried a different remote , but still the same.
    Any help appriciated, thanks --Ian Palmer.
I'm trying to record a DVD and get a message that says "Unsupport" or "protect". I did call Panasonic and they said it needs to be serviced. I just used it the othe day and I can't understand the failure. Whiel on the phone with the Tech support we did try three different + R discs: Imation, TDK and Sony. Can someone help me?
Posted on Oct 11, 2008
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Machine stuck on remote dvd 2 setting
Try holding 1 and enter at the same time for more than 3secs
Nov 16, 2009 | Panasonic DMR-E50 DVD Recorder
Need to unlock region code for Panasonic DMR-ES30V DVD Recorder/
evidently you have to purchase this code from panasonic cant find any other info on line
Apr 05, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Setting the clock on the dvd recorder
Follow this sequence on the remote control:
Press FUNCTIONS/To Others/Setup/Others/Clock to access the clock setting mode. There, you will have the choice of Auto or Manual. Take your pick and away you go!
Apr 02, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Mar 12, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
My Dad recorded all his VHS tapes and made DVD's on the Panasonic DVD Recorder DMR-ES30V and now they wont play on any DVD player except for the DMR-ES30V. I believe he recoreded them with a lock so they...
Hi and welcome to FixYa,
My compliments to the foresight of your father. Your described concern is not caused by a "lock". It is indicative that the recording session was not 100% completed. Rather than 'crack', what is required is the final step in the recording. All the DVDs must be "finalized" in the same machine that recorded the movies, the Panasonic DVD Recorder DMR-ES30V. The finalize option would be in the MENU/Settings and must be enabled. Finalization per disc would take some time.
Good luck and thank you for using FixYa.
Feb 18, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
PANASONIC DVD RECORDER
Appreciate the direct "Ask Me".
Since both are record capable:
  • hook the Video and Left/Right Audio OUT of the DMR-ES30V to one of the composite/matching INPUT of the DMR-EX88;
  • use the DMR-ES30V as a player and the DMR-EX88;
  • to be able to watch and monitor the output, temporarily hook up the OUTPUT of the DMR-EX88 to the INPUT of the TV.
Nov 23, 2008 | Televison & Video
Panasonic DMR ES30V DVD Recorder/VCR
take it to a tech to check the system control chip could be bad.good luck
Jul 06, 2007 | Panasonic DMRES30V DVD Recorder/VCR Combo
Panasonic DMR-ES30VS DVD Recorder/VCR Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
