Question about Sony RDR-VX525 DVD Recorder/VCR
STANDBY How do I set it to standby... when no response from remote and where is the title button
    President:
  • 2,712 Answers
Page 22 in the user manual will explain how to rectify this. You need to set up both the recorder and remote to be DVD3. I posted the link to the manual on the premium question..
Posted on Jul 05, 2008
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
Tip
Region free code for JVC XV-511BK
Make sure there is no Disc in the tray.
Shut off the unit and unplug it from the AC outlet.
Press and Hold the "Play" and "Open/Close" keys, simultaneously on the player and not the remote control.
While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display).
Press DVD Menu twice on the remote.
When the display reads 000 5858 use the up and down buttons to change the 000 to 02E.
Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
Press Enter on the player.
Press Standby and wait 5 seconds.
Press Standby again.
Your player is now set to the region you requested.
If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
on Mar 07, 2010 | Televison & Video
Tip
JVC XV-S300 and XV-S500 Region Code Change
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
on Jan 02, 2009 | JVC XV-S500 DVD Player
Wont go on standby
Possible that the processor section needs to be checked. When the remote is clicked to standby and if there is no response even if the remote is working perfectly with other modes then the power - off button and IR trigger from the remote must be checked to work. Use a mobile camera to see if the remote is emitting IR with the power off button pressed.If so the processor section and the standby out must be traced.
Jan 20, 2012 | Televison & Video
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Cheers,
Jun 22, 2011 | Sony DVP-C670D
Trying to set up a Zeikos ZE-WRL3 with a Nikon D^) and it won't work could soeone guide me through it?
I assume you mean a Nikon D60? I'm also assuming the ZE-WRL3 is FULLY compatible with the ML-L3.
Set the release mode to one of the remote modes. Quick-response takes a pic as soon as you press the button. Delayed-response waits two seconds, allowing you to hide the remote behind your back. Either way, the usual caveats about focus and metering apply.
There should be a section in manual titled "Release Mode" or "Shooting Mode" that gives full details.
Sep 28, 2009 | Nikon DH4730 Remote Control
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
Unlocking my DVD Player
Try this,it should work....Rod
To change the current region setting on this player
1. Press the Standby button on your remote control to place the unit into Standby
2. Press the Standby button on your remote control to turn on the unit
3. Press the Open/Close button on your remote control to open the drive tray
4. Press the Clear button on your remote control
5. Press the 1 button on your remote control
6. Press the 3 button on your remote control
7. Press the 6 button on your remote control
8. Press the 9 button on your remote control
9. Press the 0 button on your remote control
10. Press the Open/Close button on your remote control to close the drive tray
11. Press the Standby button on your remote control to place the unit into Standby
12. Press the Standby button on your remote control to turn on the unit
Jul 16, 2008 | Durabrand Televison & Video
STANDBY
OK..I see the problem now.. Basically, you have to set both the remote and the recorder to the same command mode. (Default id DVD3). Please see the user manual I have posted in your premium query. It will tell you how to do this on page 22.
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Bose 3.2.1 GS II region free
TRY THIS Multi-Region:
1. Using the remote control, key in the following: 9, 4, Shuffle, Stop, Mute.
To set a specific region:
1. Using the remote control, key in the following: Open (to open the tray - if already open, no need to press it), Stop, Shuffle, followed by the region number.
2. Press the Enter button on your remote control.
Jun 07, 2008 | Bose 3·2·1 II System
Sony RDR-VX525 DVD Recorder/VCR Logo
66 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
