Question about HP Compaq Presario V2000 Notebook
It won't turn on!!!!
Sometimes when i'm just going to be gone for a few minutes I just shut the computer. But when I opened about an hour or two later it wouldn't turn on when I pressed the power button, so i assumed that the battery needed to be charged so I put the charger where it's suppose to and I tried the power button again but it still wouldn't turn on. Whats wrong with it?!?!?!?!?!
*If you solve this here's my e-mail Hothed91@aol.com
  • chevykat5150 Jul 30, 2008
    I always had my PC opened up. One evening, I thought I'd shut her down-figured it'd be a good idea (since I NEVER turned it off). The following morning, I went to turn it on...and NOTHING. Bought a new power adapter. Still, nothing. No lights come on. I tried taking the battery in and out, plugging it in with no battery, and removing the RAM and putting it back in. Nothing!? AHH...PleASE heLP!!! It's almost been a year since I've had my laptop working! I need my baby!
  • 300 Answers
Common problem with this model, it requires a new system board. If you keep trying to turn it on eventually it might spring back to life
Posted on Jul 05, 2008
2003 VW Jetta wont start after turing off motor sometimes for hours
if it uses a carburator it might be overflowting have the carb checked and the petrol flowter re- ajusted
Dec 18, 2013 | Cars & Trucks
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
HELP! 50 inch projection RCA HDTV. Turn it on sometimes minutes later, sometimes hours later the picture will go black with sound on once or twice and then it will power itself off entirely. None o
I got all the components you need for your tv I'm parting out mine it was oar king break when I turned it off we bought a wall hanger if you need parts call 270 589 8074
Oct 27, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
My motorola triumph won't send pictures mms
Check your APN settings
http://www.virginmobile.co.za/support/support-category/general-services/gprs-settings-and-usage/gprs-and-mms-settings-for-android-phones/
different locations you go sometimes have dead spots so less signal wont send mms. you can also connect to your home/public wifi to send mms,
May 03, 2017 | Motorola Mobility Triumph
We installed a new ceiling light fixture in our hallway. I used the 13W CFL bulb. Just recently, I turn on the light and a hour or so later it turns off. It takes a few minutes before I can make it turn...
DON"T USE TILL YOU FIX- the connections inside fixture are getting hot and expanding- OPEN SHORT_FIRE HAZARD- that is why going out after an hour and then works after a few minutes of cooling- take down and check you connections
May 18, 2011 | Hardware & Accessories
My 95 Ford Windstar has just developed a rather distressing problem. In the morning, I get in my van and everything is fine. A few hours later, when I get in my van and start it, there is a warning bell...
one of the door ajar switches are sticking. needs to be put on the computer to find out which one. only other way is to go around and unplug the switches until your light shuts off.
Mar 30, 2011 | Ford Windstar Cars & Trucks
My toshiba tv turns off on its own, sometimes it will stay on for a few hours, other times only after 5 minutes it will go of
Ok This may be due to having a heated CPU/MOTHERBOARD and can cause a fuse to shut down to stop further damage like when a computer detects problems. My solution would be to get an airated space and when it shuts down feel the back of the tv to feel for heat, open windows when turning on or blow a cool hairdryer into the back of it.
Feb 06, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Dell OptiPlex GX260 PC Desktop keeps switching its self on, can any one help, i click start - go to turn off computer - then turn off, the pc then shuts down, then a couple of hours later i hear the fans...
Have you gone into the BIOS to make sure there aren't any power managment features? Do you get the same thing happening if plugged into a different wall socket? Sometimes bad power surges can cause this problem. Other issues have been known to arise from motherboard problems. Or NIC power settings...strangely enough...a quick way to test if it's NIC related might be too unplug any cables from the NIC to see if it stays on or not? There are power settings on NICs in advanced settings. Let me know if any of that helps and remember to rate the solutions. Thanks!
Mar 31, 2009 | Dell OptiPlex GX260 PC Desktop
HP Compaq Presario V2000 Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
